Old 05-18-2005, 04:58 PM   #1906
Rob Phillips's Avatar
Jimmy Mac,
I might try to come down some time next month, where are you on setup. close to stock, white/blue springs, #3 pistions, roll centers, etc.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 05-18-2005, 05:10 PM   #1907
Trader Rating: 55 (100%+)
we still have to use foams on asphalt from time to time
i had cut them down to 2.5mm total height, but they just dont want to hold in place anymore.
tones is offline   Reply With Quote
Old 05-18-2005, 06:45 PM   #1908
SpeedTech's Avatar
Originally posted by Matt Howard
Get with Masami when he gets there. My car sucked last year until I got his setup, I only had to tweek it very slightly to suit my driving style.
What was really cool from Masami and the Yokomo Japan camp was that they posted their setup for everyone to see (including other racers) on the post behind their pit. So if you need a very good baseline for setup, it's right there don't know if they are going to do that again this year though
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 05-18-2005, 08:31 PM   #1909
JimmyMac's Avatar
Rob, that would be cool. Yeah, kit setup is about the best so far. Even though I have fastest lap with a spool. Anyways, changes would be goin from 3degrees to 2deg rear toe. Maybe even down to 1 deg. I ran 40wt/30wt on mine and Jairo ran 30wt/30wt. I ran my front shock mounted all the way in on the arm. Jairo ran his all the way out. Droop was 6/5 for me. I think Jairo was about 6/5 or 7/5. Not sure. If you can break into the 20' sec lap times in Stock, you are doin good.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-18-2005, 08:36 PM   #1910
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
For Ceramics Bearings there are two kits out right now
Acer racing has them with rubber seals for $99.99
Boca has them with metel sheild for $165.00
I have the Boca and once i cleaned out the heavy grease they are ultra smooth.
The Acers take a good long time to break in the seals...I know this from my SD with Acer's
Hope this helps,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 05-18-2005, 08:37 PM   #1911
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Default Ceramics
I have a big order in for Ceramic bearings...Should have kits ready in 2-3 weeks.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 05-18-2005, 08:48 PM   #1912
Default Re: Ceramics
EA
Hey EA,
Any word on the chassis?
Thanks,
Stephen <><
Old 05-18-2005, 09:08 PM   #1913
Team EAM
Yea the guy designing them for me just got done with the Xray kit today. It took him a lot longer than expeceted because of some big projects at his day job. So the yok got pushed back a bit. I will know more next week.
EA
Contact Us
Old 05-18-2005, 09:53 PM   #1914
highwayman's Avatar
Originally posted by noline
Does anyone know wich color rayspeed springs come with the car also would a 120 64p spur gear fit the Yokomo BD.
you could make it fit... but you'd have to shave off some material from the carbon fiber bulk head brace... some guys have been using the 120 spur, and don't have any problems with it.
highwayman is offline   Reply With Quote
Old 05-18-2005, 10:01 PM   #1915
highwayman's Avatar
Originally posted by KilRuf
Well I just got some aluminum steering knuckles from PrecisionRC in Hong Kong. The steering arm is pretty thin. So I'm not sure if they will be that durable compared to the ever so ellusive Team Suzuki aluminum steering knuckles. Anyways, they look as though they will clear TC3/4 dogbones for those who are interested. Only like $16 for the knuckles. They are also stock offset (1mm trailing). I'll take photos once they are installed tonight...
interesting, let us know as soon as you tried them out... since i'hv been using the TC4 bones, i switched back to the stock knuckles, which BTW, i also had to grind down a bit...
Old 05-18-2005, 10:11 PM   #1916
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Steve Wang
That would be a really dialed way to start off
Old 05-18-2005, 10:20 PM   #1917
Matt Howard's Avatar
Yes it is, he had his setup posted after a couple rounds of practice. After my car sucked really bad I went over and copied it and was much better. Masami is one of the nicest racers out there, and speaks pretty good english as well.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-18-2005, 10:22 PM   #1918
Hopefully I'll get a chance to hang out with him this time around, bieng in the right pit and all
Old 05-18-2005, 11:14 PM   #1919
JimmyMac's Avatar
highwayman, they are on the car right now. Just been too lazy to snap a picture. Too many naps! hehe. Plus StarWars is out at the movies now.. Muh hahahaha.... I will say the kingpin and top ball screws fit really tight. Plus they are make with a left spindle and right spindle due to their design. I ended up switching left for right and right to left. Once again due to their design and the fact that I run my steering links on the bottom instead of on top. But like I said before, these spindles are pretty thin. I'd rather have the Team Suzuki ones (although they are .5mm trailing, not 1mm).
Yeah, can't wait to see Masami's Reedy Race setup. I've had pretty good luck with that setup out here. Tweeked alittle of course. But it was a good starting point for a spool... Can't wait!!
~Jimmy Mac
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-19-2005, 02:43 AM   #1920
highwayman's Avatar
KilRuf : i have the Team Suzuki ones but the TC4 bones doesn't fit them... what do you mean by ".5mm trailing, not 1mm" thanks... i always thought that the suzuki ones are the same as the stock ones...
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
