Old 05-01-2005, 10:37 PM   #1606
JimmyMac's Avatar
Rainbowten...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-01-2005, 11:10 PM   #1607
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Is it hollow all the way through, or is the center part one big mass? Yokomo USA should have them avalible this week for the rest of us
Old 05-01-2005, 11:45 PM   #1608
JimmyMac's Avatar
It's hollow just like a SpeedtechRC spool. I'm gonna use this one for stock class and maybe 19t. I'll try out SpeedtechRC's spool for mod. I might even try the Yokomo one out for Mod as well. Now I just need the center pulley!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-02-2005, 12:10 AM   #1609
Just stay off the pipes and you should be fine in mod with it.
Old 05-02-2005, 01:47 AM   #1610
highwayman's Avatar
anyone here using a servo saver? i'hv been running my BD without 1 since it came out... thankfully, no untoward incidents yet
highwayman is offline   Reply With Quote
Old 05-02-2005, 02:01 AM   #1611
Fatboy Joe's Avatar
Ive been running a spool in mod and the only problem that i overlooked are the stock cvd pins. i broke 6 pins in 6 runs. i bought a rayspeed cvd set (made by mip), used tc4 bones, and problem solved! my car handles great but got to try my long awaited jrxs first too see which suits me better coz i break most ofbthe time due to aggressive driving. i also got a tip on how to make a direct center pulley, just takes lessvthan 5min w a dremel and a nice thin bit, and the pulley pin. thats why theres another hole in the layshft, thars for the pin to hold the main gear in place, u need to take out one bearing though but its ok, measure the pin over the main gear adapter and mark where to dremel, then your done, now you got a center one-way and a direct diff all in one by jusr slipping in the pin.
Fatboy Joe is offline   Reply With Quote
Old 05-02-2005, 03:28 AM   #1612
chaini's Avatar
Default center direct pulley
could you post a pic?
chaini is offline   Reply With Quote
Old 05-02-2005, 03:45 AM   #1613
Default Servo saver
The servo arm has been the weal link for us in this car.
We broke three of the standard arms during the first week.
All servo savers we could find had substantially shorter arm than the standard arm. It did not feel good to our team pilot so we haven't used after the first experiment.
I then found an old arm which I think came with a multiplex servo. The material is thicker and seems like nylon when the original arm feels more like plain hard plastic. The nylon arm is almost the same length as the original.
This arm has now worked well even if it has taken a couple of hits in the last weeks racing and practising.
jarkko is offline   Reply With Quote
Old 05-02-2005, 03:51 AM   #1614
utieh's Avatar
Default Re: center direct pulley
utieh is offline   Reply With Quote
Old 05-02-2005, 03:51 AM   #1615
Trader Rating: 55 (100%+)
you could try a kimbrough mid sized servo saver on a diagonal and just cut away the excess material.
tones is offline   Reply With Quote
Old 05-02-2005, 04:29 AM   #1616
seri's Avatar
Default Servo Saver
I've just used a Tamiya High Torque Servo Saver without any probs:
seri is offline   Reply With Quote
Old 05-02-2005, 05:53 AM   #1617
pheyhoe's Avatar
R/C Tech Charter Subscriber
I was just wondering, are those both your cars?
If so, why are they so different???
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 05-02-2005, 07:33 AM   #1618
seri's Avatar
No, no, these were the two first BD's which were at a race in switzerland once.
The one with the servo saver was mine and the other was from Jean-Marc Betticher (multiple swiss national champion)
http://translate.google.com/translat...language_tools
Old 05-02-2005, 09:17 AM   #1619
Matt Howard's Avatar
I put a kimborough medium servo saver on my car as soon as I built it. In the past I've had the yokomo servo arms "skip" on the servo's output gear after a hard hit, now I always run some type of servo saver.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-02-2005, 09:20 AM   #1620
rc-zombies's Avatar
the Tamiya High Torque servo saver works the best with the car.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
