Old 04-28-2005, 08:22 AM   #1546
chaini's Avatar
Default Masamis BD
realrc.net has published some new pics from masamis BD...
chaini is offline   Reply With Quote
Old 04-28-2005, 09:35 AM   #1547
Matt Howard's Avatar
Originally posted by utieh
I've just finished to build the kit yesterday, I was wondering which tension the belt needed, the stock setting seems to have to much tension.
Concerning droop where should I start?
Gilles
I used the stock rear tension but loosened the front up by one of the little marks on the bulkheads. The belts seem to loosen up a bit after you run them for a bit.
For droop I started with 6 in the front and 5 in the rear and it seemed pretty good
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-28-2005, 09:39 AM   #1548
pheyhoe's Avatar
R/C Tech Charter Subscriber
Default Re: Masamis BD
What front hubs/carriers are they????
Look like the ones off the old MR4C Special/Custom
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-28-2005, 09:47 AM   #1549
utieh's Avatar
Thanks a lot.
Acually I have the loosest belt tension
I'll go back to the stock setting
utieh is offline   Reply With Quote
Old 04-28-2005, 10:30 AM   #1550
iamramos's Avatar
Default Re: Re: Masamis BD
pheyhoe:
ZS-4134 Front Hub Carrier (4 Deg) for MR-4 series. (requires little mod. to use for SD cars) 6.50
also:
ZS-4135 Front Hub Carrier (5 Deg) for MR-4 series. (requires little mod. to use for SD cars) 6.50
ZS-4137 Front Hub Carrier (7 Deg) for MR-4 series. (requires little mod. to use for SD cars) 6.50
iamramos is offline   Reply With Quote
Old 04-28-2005, 11:10 AM   #1551
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Gilles
The stock tension is actually alright because the pulleys are larger now and the belt doesnt get pinched as tight over the pulley. It takes a few runs for the belt to break in but it will be fine once it does.
Old 04-28-2005, 12:31 PM   #1552
Good news gang, the direct center pulley and front spool should be avalible by the end of next week.
BD-501SAS Front solid axle (composite w/ alum. outdrive savers)
BD-630 Direct drive pulley
Old 04-28-2005, 01:23 PM   #1553
pheyhoe's Avatar
wohoooooooooooooo
Oh by the way, is the front diff pulley available?? thats all i need to make a diff as balls, rings, outdrives are already available...
Old 04-28-2005, 01:25 PM   #1554
rc-zombies's Avatar
wohoooooooooooooo
Wouldn't you need the rear diff pully to build a diff?
Old 04-28-2005, 01:53 PM   #1555
Yep, the rear diff will work fine up front.
Old 04-28-2005, 03:31 PM   #1556
pheyhoe's Avatar
Ok, i knew the rear would fit i just didnt know if it were available for single sale yet
Heres one for Mr Shookie ..
Taken in a hotel over the weekend :P
Old 04-28-2005, 03:52 PM   #1557
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
LOL
That is great.....
My BD has made its way through the old testament but just started the new...LOL
Great pic though....
Got my Boca Bearings today....Even though I am sick I still went ahead and cleaned them out of the heavy lube and then put in some ACER ceramic bearing oil....well it is just the same as Royal oil but a tad bit thinner. These bearings are very nice...Fit perfect but it seemed I needed to add a couple shims in all the diffs...Oh well probably just wear....But the drive train feels silky smooth now. Ran the new bearings in for about 20min @ 2.5V with a stock motor... The car doesn't make a peep of a noise now...
Will run some lap times to see if they really make any difference...
If I ever get over this silly cold....Came out of no where...
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-28-2005, 03:56 PM   #1558
pheyhoe it does look like you got lots of extra wire....LOL
Maybe a barber,,,,LOL
Just messing with you...
How everything over on your side of the pund?
Things are good here just trying to get rid of this cold...*COUGH*LOL
Stephen <><
Old 04-28-2005, 04:29 PM   #1559
pheyhoe's Avatar
Thats Sleightys car, we had left all the wires long because we were using batterys that had differently positioned connectors etc, and there was a possibility that things may have had to be swopped over from different cars so we figured just leave them long
The only reason the reciver wires are stuck up like that is becuase they were taped, it was very wet
Old 04-28-2005, 09:36 PM   #1560
JimmyMac's Avatar
Sorry Rob. No extra diff pulleys here. I have one in my car. And my other friend has one. But the other guy doesn't. So they will be racing a TC3/4.
Anyways, catch yall soon. One last time for the BD on carpet before asphalt season!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
