Old 04-27-2005, 09:58 AM   #1501
Also the battery trays on speedtech, it comes in a pack of 3. Is that 3 different size trays or 3 of the same size trays?
Dan Hughes is offline   Reply With Quote
Old 04-27-2005, 09:59 AM   #1502
Matt Howard's Avatar
Default Re: Another question???
Originally posted by Geppetto
Is it ok to clean/degrease the one-way diff on the BD. I notice that my front wheels don't spin very freely. At first I thought the problem was the bearing, but upon closer inspection, I found that the outdrives aren't spinning freely.
If I can clean the one-way out, what type of lubricant should I use to re-lube it?
I wouldn't worry too much about the oneway not spinning too freely. If you do want to clean it use a light weigth bearing oil to relube it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-27-2005, 10:00 AM   #1503
Originally posted by Dan Hughes
Matt, do you know a date when a locked pulley will be released. I want to get a BD but i will not be as fast with it with a centre 1 way.
I'll try and find out today for you.
RCTech #361
Old 04-27-2005, 10:00 AM   #1504
Trader Rating: 35 (100%+)
Default Re: Re: Another question???
Originally posted by Randy Caster
XRay makes a 1 way bearing lubricant. Is your car brand new or does it have a few runs on it?
I've run about 6 packs (2 practice, 3 Qualifiers, 1 Main) on my new BD.
If I spin one of the front wheels, it doesn't spin very long or freely.
Geppetto is offline   Reply With Quote
Old 04-27-2005, 10:11 AM   #1505
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: Re: Another question???
Thats good then, just means your 1 way bearings are still new. They will spin more freely as they get older.
Old 04-27-2005, 10:17 AM   #1506
utieh's Avatar
I've just received my kit yesterday, I also bought some spare arms and C-hubs but it seems that the material of the kit is not graphite (color is black and feels a little bit softer), I also noticed that the droop screws are larger on the kit arms, so probably the spare arms I bought are SD's HD arms...so My question is the BD plastic a new material???
utieh is offline   Reply With Quote
Old 04-27-2005, 10:20 AM   #1507
The BD arms are a heavy duty material, it's really strong, but it does flex. You can use the SD-008G arms on the car with no problems, but the new arms SD-008HG are floating around, I've seen them, just not in any big numbers yet.
Old 04-27-2005, 10:24 AM   #1508
utieh's Avatar
Thanks Randy, they BD arms look really beefy compared to the first SD's, even the C-hubs look huge
Old 04-27-2005, 10:25 AM   #1509
I have Masami's and Pumpler's setup from the LRP race last weekend but it's too big for me to put it on here. If anyone wants it just email me at [email protected] Maybe you'll have better luck posting it on here
RCTech #361
Old 04-27-2005, 10:25 AM   #1510
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Hey Randy will the SDW arms fit on the car? May make the car rotate harder being a little shorter. I ordered some from speedtech....gona try it this week if they fit.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-27-2005, 10:27 AM   #1511
You cant as the hingepin mounts need to be longer for the short arms
Old 04-27-2005, 10:28 AM   #1512
EA
the SDW front arms are shorter so you'll have a narrower front width. They should fit with no problems though.
RCTech #361
Old 04-27-2005, 10:30 AM   #1513
Team EAM
Yea I guess thats true....Maybe that will be good for carpet... Because you have to space the wheels out quite a bit with Jaco foams to get them to fit. Im pretty sure its enough to make up the difference.
EA
Contact Us
Old 04-27-2005, 10:31 AM   #1514
The driveshafts will be too long if you run short arms?
Old 04-27-2005, 10:32 AM   #1515
oops, you might be right on that one
RCTech #361
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
