Hacker Brushless TensorIC ESC and Skalar Motors >
Old 06-25-2012, 11:27 AM
Default Hacker Brushless TensorIC ESC and Skalar Motors
Hello everyone!
I just wanted to take a little time to start a thread regarding the new Hacker TensorIC ESC and Skalar motors. If anyone has any questions please ask away.
Skalar 10- MSRP- $84.99
A two-piece CNC machined motor housing from 7075 aluminum, with a design for maximum cooling, ensures that the engine can make over the entire duration of the race, the maximum torque and full power without having to make compromises. The adjustable timing plate on the back of the motor provides maximum flexibility and can be adjusted from 0 to +40 . In conjunction with our TENSORIC10 controllers and a sensor cable this motor give you the perfect combination. The SKALAR10 motors, because of their U-shaped solder tabs they can be properly fitted and soldered in vehicles with limited space.
Of course, a SKALAR can be completely disassembled and all components are as spare parts available.
FEATURES
o weight-optimized design
o optimized cooling
o Adjustable Timing
o U-shaped solder tabs
o precision ball bearings
o maintenance-friendly design
o 12.5 mm standard rotor
Available from 3.5 turns to 21.5 turns.
Skalar SC- MSRP $104.99
Specifically for the short course class, we have built a stronger version of our SKALAR 10 motors. We choose the 540'er engine size, as in some vehicles, there simply is not enough space for a 550 version. By using a high-strength sintered rotor with 4-pole magnet with 12.95 mm diameter, With the 4 Pole magnets this allows for more torque which the 4x4 vehicles require., the total power is transmitted through a 5mm shaft. The SKALARSC is the motor for all short course trucks!
FEATURES
o Compatible with all speed controls sensored or sensorless
o CNC machined from T6 aluminum crankcase
o 4-pole rotor for maximum torque
o High performance ball bearings
o Sensor Connection
o superior thermal stability
o 5mm shaft for better power transfer
Available in 4.5, 5.5 and 6.5 Turns
Skalar 8- MSRP $149.99
This Skalar 8 brushless motor is our biggest motor from this series. Our test team is thrilled by the performance! The SKALAR8 has a ribbed housing T6 aluminum. The holes for the mounting of the engine were mounted so that it both with M3 motor screws, as well as M4 can be fitted in the vehicle. Inside, we use a 4-pole rotor, which is balanced to improve performance Motor also includes low friction ball bearings. As with all of our car motors in the Skalar series, this motors includes U shaped solder tabs.
FEATURES
o maximum efficiency by fine-grained components
o Fully rebuildable
o CNC machined from T6 aluminum housing
o Sensor Connection
Attached Thumbnails Hacker Brushless TensorIC ESC and Skalar Motors-skalar_sc.jpg   Hacker Brushless TensorIC ESC and Skalar Motors-skalar_10.jpg   Hacker Brushless TensorIC ESC and Skalar Motors-skalar_8.jpg
kyle478 is offline
Old 06-25-2012, 12:05 PM
theatriks's Avatar
Where can u buys these?
theatriks is offline
Old 06-25-2012, 12:19 PM
Geberit's Avatar
http://www.aero-model.com/Hacker-Car...0th-Scale.aspx
Geberit is offline
Old 06-25-2012, 12:40 PM
syndr0me's Avatar
Trader Rating: 32 (100%+)
Stormer has 'em in stock.
syndr0me is offline
Old 06-25-2012, 01:32 PM
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I really like motors that sell replacement parts.
These bad boys run cool.. haven't needed a new part yet
hanulec is offline
Old 06-25-2012, 03:43 PM
Default Tensoric ESC's
Tensoric 10
A CNC milled from solid metal housing is used directly for cooling and effectively prevents the penetration of dust and splashing water.
To further improve the cooling performance a fan is supplied with 4 mounting holes. The initialization of the controller works with a simple keystroke.
The TENSORIC10 can be programmed directly via the SET button, or via an optional programming box.
2 sensor ports for optimized wiring
Features Features
o low internal resistance
o splashproof
o softsensored - the controller continues to break the sensor signal
o easy to program using Set button or hacker PROGBOX
o upgrade capability via optional programming box
o switched BEC
o Programmable Timing
o Programmable start-up stages
Specifications
Constant current 160A
Max Power 760A
Internal resistance 0.00025 ohms
Battery Type 1-3S LiPo/LiFe * 5-9S NiMh 1-3S LiPo / LiFe * 5-9S NiMh
BEC 5.8 V max. 3A
LxWxH 41.5 x30x20.4mm without fans
Weight 44g without cable
Tensoric SC
The TENSORICSC we developed specifically for the 4x4 Short Course class.
With the size and weight of a Short Course truck the requirement for power is increased.
In connection with our Motor is SKALARSC, this controller is the perfect unit for the new racing class.
Features Features
o splashproof
o easy to program using Set button or programming box
Specifications
Constant current 100A
Max Power 520A
Internal resistance 0.0007 ohms
Battery Type 2-3S LiPo/LiFe * 6-9S NiMh 2-3S LiPo / LiFe * 6-9S NiMh
BEC 6V max. 3A
LxWxH 53.6 x 36.36
Weight 74g without cable
Tensoric 8
With the TENSORIC8 we have developed a controller that is specifically tailored to the needs of large models.
The design provides up to 6S Lipo use.
The TENSORIC8 comes preconfigured with wires soldered to the ends of motor and controller and can be connected via a plug-in system.
Features Features
o splashproof
Specifications
Constant current 180A
Max Power 760A
Internal resistance 0.0002 Ohm
Battery Type 2-6S LiPo/LiFe * 6-18S NiMh 2-6S LiPo / LiFe * 6-18S NiMh BEC 5.8 V max. 3A
LxWxH 55.6 x 46.6 x34mm
Weight 106g without cable
kyle478 is offline
Old 06-25-2012, 03:45 PM
Default Tensoric Pictures
Pictures of the new Tensoric ESC's
Attached Thumbnails Hacker Brushless TensorIC ESC and Skalar Motors-tensoric_10.jpg   Hacker Brushless TensorIC ESC and Skalar Motors-tensoric_8.jpg   Hacker Brushless TensorIC ESC and Skalar Motors-tensoric_sc.jpg
kyle478 is offline
Old 06-25-2012, 03:59 PM
Default Touring Car
For a setup for a 13.5T motor at Reedy Touring car race. I placed 3rd in the 13.5T class. Motor ran very cool and very powerful all weekend. The motor not only had great straight away speed but had tons of pull out of the corner. Here is the setup I was using.
Skalar 13.5T motor w/ 37 degrees of timing on the endbell.
4.2 FDR
Tensoric 10 ESC Blinky
Let me know if you have any questions.
Kyle Bergstrom
Attached Thumbnails Hacker Brushless TensorIC ESC and Skalar Motors-car1.jpg   Hacker Brushless TensorIC ESC and Skalar Motors-car2.jpg   Hacker Brushless TensorIC ESC and Skalar Motors-car3.jpg
kyle478 is offline
Old 06-25-2012, 05:28 PM
btsai's Avatar
Do you think we'll see an ESC made for 1/12 1S racing any time? (with 6V out)
btsai is offline
Old 06-25-2012, 07:56 PM
Does the ESC have the two Sensor ports like the orion ?
Madmaxaus is offline
Old 06-25-2012, 09:04 PM
hanulec's Avatar
I was sitting with Kyle at the Reedy Race - the unit looks nice. It has a metal case .. and comes with a fan in case you think it is necessary to use it (probably need for mod).
Yes- two sensor ports.
You program it through the sensor port too.. there is a hookup from the programming box to a sensor cable.
hanulec is offline
Old 06-25-2012, 09:06 PM
I will check into this. Expect an answer soon
kyle478 is offline
Old 06-25-2012, 09:26 PM
With the Skalar 10 spec/ stock turn motors is there any factory timing or is 0 0 degrees
Old 06-25-2012, 09:30 PM
olhipster1's Avatar
Trader Rating: 100 (100%+)
Default Pimp
I have to admit I eye fondled the super pimp speed control at Reedy....
This has to be the best looking speed control I have seen....
Very solid feel
Performance! I do believe Kyle laid it down at Reedy....
This will be my next purchase.
Kyle thanks for the info at Reedy.
olhipster1 is offline
Old 06-25-2012, 11:15 PM
syndr0me's Avatar
I've got an almost new 13.5 that's looking for a good home. My motor situation changed recently, so I'm culling the herd.
The design of these motors is fantastic. The timing adjustment is super smooth, too.
syndr0me is offline
