Track making thread
#331
I recently built another road course track for a new track. I used the materials they provided this time, so it doesn't look quite as nice since it's mostly 2x4's. However, I did add a dozen soft corners, which helps. Low res pictures:
http://www.rndracepark.com/images/100_2197.jpg
http://www.rndracepark.com/images/100_2198.jpg
The owner's did not want me to use velcro, so we need a lot of weight. Does anyone know where to buy bags of stones? Another track used the bags of stones, and they worked beautifully. The only downfall was the choice of stones they used were very dusty. But that can be easily remedied.
#333
This is a cool thread!
I'm making an offroad track for 1/10 and 1/8 scales. What is the best/cheapest material to make the barriers from? I've seen wood and PVC piping mentioned. Is there anything else? What size PVC works best? Thanks for any input!
#335
Place it in non critical areas to back up the boards.
Another way to make a great track is to use 1"X4" outer boards with small sections of 2"X4" in side. Put a finger out of one end, then inset the 2"X4" other end so you can lock them together when ever possible.
Make sections different lengths 10Ft and 5FT for many track possibilities.
You can also get some 1/4" flexable plastic cut it into appropriate width strips and to screw into the tops of the joints to help secure them. Triangle pieces in the corners also.
I have attached some pics to show you some examples.
#339
any ideas for rally tracks? not crazy jumps but maybe good for hardpacked dirt. not too big either.
#341
I see alot of discussion of track layouts, but not track materials. Where do I get soft corners?
#342
I've been thinking about redoing our club's indoor track for 1:12 (35'x70').
I was going to use 9' vinyl downspouts for the boards since they are flat sided compared to rouned pipe. I would stuff each end with a short piece of 2x4 and screw in two button head screws vertically down the center of the 2x4.
To connect the boards I was going to take a 4" PVC pipe and cut 2" wide rings. I would keyholes to match the screws in the 2x4 stuff in the downspout.
The idea was simple about the rings. Key the holes the holes at, 0, 90, 112, 120, 135, 150, and 180 (as viewed on a compass). That should make any bend possible from the slight 22 degree to a very sharp 90 degree.
#343
One of the easy parkinglot track systems I have seen, 2x4's on end with hold drilled middle of each 3 inches back, use u bolt sitting through the top with overlap in direction of travel.
#345
so it turns out my new house has a strip 20 ft by 60 feet to make a small outdoor rally track. ideas are apprecited. pics as events warrant.
