Old 02-21-2005, 06:06 AM   #1
TRAJ's Avatar
Default Discharging at 30amps???
Hi Guys
Discharging at 30amps is this too harsh?
What do you guys recommend for stock racing?
I would like to purchase this Discharge tray but ive been told that 30amp might be too harsh on the batteries?
http://www.speedtechrc.com/store/ebp...nid=60&id=4710
Any help as to what i should do or buy?
Thank Guys
TRAJ is offline   Reply With Quote
Old 02-21-2005, 06:09 AM   #2
Rob Phillips's Avatar
Read this
Rob Phillips is offline   Reply With Quote
Old 02-21-2005, 06:12 AM   #3
TRAJ's Avatar
Im asking about that Tray in particular
Old 02-21-2005, 06:21 AM   #4
TRAJ's Avatar
Hi Guys
What amp do you guys discharge your packs at?
Old 02-21-2005, 06:25 AM   #5
1fastdude's Avatar
Trader Rating: 15 (100%+)
30 or 35 you can't go wrong. 35 will weed out your weak packs if you are cycling.
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 02-21-2005, 06:33 AM   #6
TRAJ's Avatar
Would it be better to use a 20amp discharger as its less strain on the cells?
Or will the 30amp increase performance somhow?
Old 02-21-2005, 06:34 AM   #7
1fastdude's Avatar
Use the thirty. The new 0-30 indy discharger is awesome.
Old 02-21-2005, 06:41 AM   #8
TRAJ's Avatar
Thanks again fastdude!
Ill try get my hands on a 30amp one!
Old 02-21-2005, 07:18 AM   #9
Hi,
You might also consider the Spintec Battery Manager.
See this thread for more info:
http://www.rctech.net/forum/showthre...threadid=59147
It has the benefits of a 35 amps discharge, without the stress on the cells.
Erik Jonk is offline   Reply With Quote
Old 02-21-2005, 07:48 AM   #10
koabich's Avatar
Send a message via Yahoo to koabich
That is an excellent discharger tray. I have 2 of them and use it all the time. Since the cells were matched at 30amps, I don't think you'll have any problem.
koabich is offline   Reply With Quote
Old 02-22-2005, 02:55 AM   #11
TRAJ's Avatar
Kool thanks for your imput guys
Some more Qs would discharging/equalizing one a 20amp tray give the packs less performance than doing it with a 30amp one?
Cause ive seen people use 30amp and 20amp
Sorry to be a pain just want to know whats best for my cells.
This is for stock racing
Old 02-22-2005, 03:07 AM   #12
megalomanmemble's Avatar
Send a message via Yahoo to megalomanmemble
Does NIMH need Discharger ???
All R/C is Good !
megalomanmemble is offline   Reply With Quote
Old 02-22-2005, 03:37 AM   #13
30 and 35 amps during matching and cycling , to find out which packs are best is obviously fine(as long as you don't overheat the pack).......Aside from that ,Iv'e never found a reason that warranted doing my regular discharging above 20 amps.....I believe it's extra heat for nothing.....IMO.... NIMH cells don't have the memory for it to make a noticable conditioning difference in the long run....... "especially for stock racing" like you mentioned
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 02-22-2005, 03:48 AM   #14
Yes NIMH need's a discharger, and an equalizer to get the most from your packs.......
Old 02-22-2005, 01:59 PM   #15
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Ya the new Integy 030 Amp discharger is great. You dont have to wait 30 min for the lights to go out. It takes about 7 min and should leave the batteries in the tray for another 30-40 min. That discharger is the only one i use. And you also dont have to worry about the little screws to screw in to connect to the battery. Just pull down the clamp and let it sit.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
discharging koolkidd Electric On-Road 25 06-08-2007 02:43 AM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 11:58 PM
Discharging and Discharging Question jeffbhhs Electric On-Road 5 12-14-2006 06:34 PM
Team Orion Digital Discharger up to 30amps Spillertwo R/C Items: For Sale/Trade 0 01-31-2006 01:43 PM
Team Orion 3000H V-MAX PLUS CLUB 30AMPS BigR R/C Items: For Sale/Trade 1 01-16-2003 08:04 PM
