Motor Turn Vs. KV What To Choose? >
Old 06-19-2012, 05:30 PM
SMR 510RR's Avatar
Default Motor Turn Vs. KV What To Choose?
Ok, I apologize in advance if this has been covered before...I am having a hard time finding anything related to my question here or anywhere.
So I am in the process of buying all the parts for my new drifter and I have everything ordered except for the motor. From the information I have found (there isnt much anywhere it seems) most people recommend 4000kv or less for a drifter because they generally have a smoother powerband with more mid range control (again from what I have read). Now here comes the part where I am getting confused. If you look at a motor from a US brand like Trinity or most "high end" brands to get ~4000kv you are looking at a 10.5t motor. Now if you compare that to some of the import brands like HobbyWing you are looking at a 8.5t motor.
So what would be the difference between the two? Obviously the rated top speed would be similar but how about torque, efficiency, etc.?
Anyone have any recommendations on what would work best? I was going to buy a HobbyWing motor but then I figured I would check out some used motors from US based companies or maybe even pony up the extra money if the benefit was worth the extra cost. And then, I got so confused I am not sure what I should buy anymore of if I should just go by turn or by KV or a little of both.
Any help is gladly appreciated.
SMR 510RR is offline
Old 06-19-2012, 05:44 PM
Spawne32's Avatar
Im kind of a newbie at the whole thing but here is what i have learned so far.
Start with the can size that you are going to use...280, 380, 540, 550, etc. Once you have determined that, calculate whether or not you are going to need lots of accel with a lower top speed or a high top speed with less accel. I found that a easy way to determine what KV will be required vs gearing is to use the rollout calculator. Rollout is basically a measurement of how many inches the car will roll per revolution of the motor.
dhrc.rchomepage.com/RolloutCalc.htm
Then last but not least, i look at the turn rating, because turn rating seems to only be a theoretical thing in brushless that is basically an estimate of torque. Finally, you have your motor timing which is done through the programmable ESC. Of course, you need to make sure your ESC can support your motor, thats why sticking with the combo kits is good for beginners.
Then you can throw 2S and 3S lipo into the mix and shit gets crazy.
Spawne32 is offline
Old 06-19-2012, 05:52 PM
Kv is really not a useful indicator of performance. I'm not sure why it suddenly became vogue to publish it. At most it might give you a ballpark idea of where to start with gearing, but even then I would ask someone who had the motor before paying any attention to the Kv rating.
I don't know much about drifting, but I would think something like a 13.5T would be plenty unless there is some benefit to spinning your wheels even faster? Different manufacturers are reasonably similar for equal number of turns. I think the differences will only be apparent in non-drift racing.
Steve S is offline
Old 06-19-2012, 05:53 PM
Spawne32's Avatar
KV is RPM X VOLT so its a pretty big indicator of how the motor performs.
Spawne32 is offline
Old 06-19-2012, 07:03 PM
That only tells you what RPM range it operates in, hence it may be marginally useful for a gearing starting point. It tells you nothing about torque, power, or efficiency.
Steve S is offline
Old 06-19-2012, 07:07 PM
Spawne32's Avatar
Theres so many unnecessary stats thrown on these brushless motors, i hardly ever know what to go by.
Spawne32 is offline
Old 06-19-2012, 07:47 PM
SMR 510RR's Avatar
This is my first drifter so I honestly have no idea I just thought it was odd that there was such a discrepancy between the import and "domestic" motors. We are talking 50% more kv when looking at something like a revtech, D3, or the like compared to a Hobbywing or Tacon, etc. That is not a small difference and there must be some power, efficiency, etc. gains and/or losses attributed to gaining 2000kv.
From what I could find a faster motor would come in handy more on something like a long sweeper where you may pick up speed through the corner requiring even more wheel speed to maintain the drift.
I think a quality 10.5 should do the trick, even a 13.5 would probably be ok. Decisions, decisions...
Thanks for your input everyone.
Old 06-20-2012, 09:21 AM
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
But the number of turns tells you everything about torque, power, and efficiency?
The answer is pretty simple: Drifting? = it doesn't matter. Racing? = use turns.
Cpt.America is offline
Old 06-20-2012, 09:57 AM
Wow, you sure burned me on that thing I never said.
Steve S is offline
