Old 02-20-2005, 09:27 PM   #16
tornado
Guest
Posts: n/a
I use this..... similar with the Robi and Fantom.
Old 02-21-2005, 12:29 AM   #17
Super Moderator
Grizzbob's Avatar
Well, it's similar except for one thing, it uses a 6-cell battery for power, instead of a more reliable & steady power source(like the high-capacity lead-acid batteries the Robi uses, or the power supplies that the Fantoms can use). I think it's important that what you use for a power source can handle a test run without losing a significant amount of it's charge(which is why Robi reccomends 12V sealed-type lead-acid batteries, & why many Fantom users have a high-amperage power supply), makes for more repeatable tests over a period of time(& both of those have voltage & current regulators to precisely control just how much voltage & current go to the motor, that's where they differ from the cheaper testers, IMO). And as for where to get more info on the Robi, well, their website(www.robitronic.com ) is probably the best source for that. Unfortunately, you won't find an American dealer for those right now, as they're made in Austria, & the only company that had been importing them(Trinity) stopped about a year & a half to 2 years ago & switched to using the Fantom(so if you're bound & determined to get a Robi, you'd likely have to go directly to the source or to a European dealer)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-21-2005, 12:52 AM   #18
EddieO's Avatar
R/C Tech Charter Subscriber
I have the Robi dyno IN stock....and am a authorized dealer for the products in the US....
They are not cheap though, $950....and you will need to still get a battery. ( I use a law tractor battery from walmart, works great).
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-21-2005, 01:59 AM   #19
Super Moderator
Grizzbob's Avatar
Oh, I stand corrected, I didn't realize someone began to import them here again, sorry, my bad...
Bob Seay
Go Pokes!!!
Old 02-21-2005, 07:39 AM   #20
ghoppa's Avatar
Trader Rating: 54 (98%+)
thanks for the info!!!!!!
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 02-21-2005, 07:40 AM   #21
ghoppa's Avatar
Later EddieO
EddieO,
can you forward me anymore info on this dyno???
I need to feel comfortable with a $950 expense before going forward.....
Old 02-21-2005, 07:41 AM   #22
ghoppa's Avatar
where can I get "specs" on this unit???
Old 02-21-2005, 07:41 AM   #23
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally posted by ghoppa
Sparxs:
"where" can I find info on this dyno?????"
Click on Motor Checker in menu
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-21-2005, 07:46 AM   #24
kartermdb's Avatar
Trader Rating: 15 (100%+)
my local hobby shop has the new CE dyno, it looks similar to the old one but is 45 amps instead of 30. it is also one of the most expensive on the market costing $1395
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-21-2005, 10:37 AM   #25
EddieO's Avatar
www.robitronic.com has all the specs.....
I use the Dyno for all my production stuff....works great.
Later EddieO
www.teambrood.com
Old 02-21-2005, 11:37 AM   #26
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
You can pick up a used CE dyno on ebay for about $450.00... I have 2 friends that have bought them on there and they work great!
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 02-21-2005, 04:36 PM   #27
SCML's Avatar
Default CS Power Checker (Dyno)
I have the CS, and I didn't like using a single pack to test different motors. I was seeing different results on every run, so I made some connectors that allow me to use 4 packs in parallel, same voltage, 4x the run time. My results are consistant through 30 runs or more now, which is more than enough to test 5 or more motors thoroughly.
I haven't taken it to the track, but it would be a lot easier to transport than a lawn tractor battery, or a high amp power supply, and all for about 1/2 the price.
No matter which dyno you have, you can't compare numbers to other dynos or even others of the same make. Calibration, slave motor, battery voltage, software... all can be a little off dyno to dyno. All dynos (IMO) are best used to quantify a good running motor (one you know is good on the track), and then use those numbers as a baseline for tuning other motors. In this case, ANY dyno that records torque of some type will be useful.
SCML is offline   Reply With Quote
Old 02-21-2005, 04:53 PM   #28
ChadCapece's Avatar
Pricewise, the Fantom is the best deal.
You can buy one off ebay for 250
Cheap laptop for under 100
Economic car battery for 30
You total is 380USD. That's a good deal. I wouldn't use anything less than a car battery. Powersupplies won't give out enough amps for the initial pull. I guess you could find something for true labratory use for about 1 grand. A car battery will give you enough dyno time to do about 50 runs before the power actually goes down.
ChadCapece is offline   Reply With Quote
Old 02-21-2005, 07:02 PM   #29
ghoppa's Avatar
thanks guys for the very informative info......
so I take it there are the following possiblities:
fantom (price wise the best offer)
robitronic
CE
and CS????
is there anyone else that is worth considering????
thanks to everyone!
Old 02-21-2005, 07:10 PM   #30
sg1
sg1's Avatar
You can get a power supply on ebay too... I picked 2 up for $50.00 (included shipping)!! They are switching supplies and go to 55 amp max. 50 constant at 13v... Just takes time to look for them...
"Wanted" Fantom Motor Dyno lesg Australia Wanted to Buy 0 09-18-2007 01:49 AM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
