Motor Cooling Scoop
Old 02-19-2005, 09:34 PM
R40Victim's Avatar
Default Motor Cooling Scoop
http://www.hpiracing.com/graphics/ne.../DSC01105k.jpg
I looked around and couldn't find one. Can anyone tell me where I can pick one up?
R40Victim is offline
Old 02-19-2005, 09:53 PM
KMW
KMW's Avatar
Default Re: Motor Cooling Scoop
eBay
KMW is offline
Old 02-19-2005, 10:03 PM
Trader Rating: 117 (100%+)
how bout trying to make one...cut out a piece of plastic, or take a piece of plastic in a shape you want, and stick it on ur motor?
Valentin.H is offline
Old 02-19-2005, 10:56 PM
Hebiki's Avatar
Trader Rating: 26 (100%+)
ride also makes them. steve at speedtech rc has them.
if you have tiny electronics you can fit two small fans in front of your motor.. like this:
Hebiki is offline
Old 02-19-2005, 11:32 PM
R40Victim's Avatar
The reason I want a simple scoop is to minimize the weight gain, and not add another electrical component to draw voltage. I've seen a few heat sink/fan combos, and that pic is of a nice setup. But I'd just like to have a simple air deflector. I'm only running in 19t class, so I imagine it doesn't generate the same heat a mod motor does...
Old 02-20-2005, 01:38 AM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Man Chris thats a Tight Fit on that Yok
-Dave
JDM_DOHC_SiR is offline
Old 02-20-2005, 01:50 AM
ford_racing's Avatar
-Dave
yeah, but how nice does it look!, now I just have to figure how to do it to mine
ford_racing is offline
Old 02-20-2005, 02:05 AM
Hebiki's Avatar
-Dave
most ppl use the futaba 9550 servo. i like overkill..so i got the Ko Propo 2363 heatsink digital servo.
plenty of space man!
Hebiki is offline
Old 02-20-2005, 02:06 AM
Hebiki's Avatar
i finally got the balls to open up my servo and shorten the wire/lead. braided it too since it was too short to heatshrink.
and found some pretty cool heatshrink so i was about to clean up my esc wires
Hebiki is offline
Old 02-20-2005, 03:26 AM
fastolfart's Avatar
Motor air scoops are also good for collecting garbage in your motor. I tried a home made one years ago.
fastolfart is offline
Old 02-20-2005, 03:34 AM
if you want overkill you should have gone with a HUGE LRP Reverseable Speedo anyways nice and clean good job you did there
-Dave
Old 02-20-2005, 06:04 AM
F. Alonso's Avatar
never the less, you still a traitor Hebiki!!
F. Alonso is offline
Old 02-20-2005, 08:44 AM
Hebiki's Avatar
got those shocks built.. i think my old car is somewhere in chicago now.
btw.. im not a 100% traitor. i still have tamiya cars... just not the double carbon deck ones
Hebiki is offline
Old 02-20-2005, 09:57 AM
the motor cooling scoop is made by RIDE.
http://www.speedtechrc.com/store/ebp...id=395&id=4608
FantomTC3 is offline
Old 02-20-2005, 10:21 AM
crACkeD ChaSsiS's Avatar
Default scoop
does the motor air scoop cool the motor down or? does it actually help?
crACkeD ChaSsiS is offline
