Old 07-11-2002, 10:43 AM   #16
The lhs(also happens to b our local hudy distributor) that I bought the hudy lathe from recommends v-guides rather than bearing guides as bearing guides tends to hav more play in them after sometime. They told me that they hav experienced more consistent cuts fr v-guides than bearing guides overtime.
I think v-guides needs less maintenance n seems to last longer than bearing-guides, but both r gd when new.
kinoshita is offline   Reply With Quote
Old 07-11-2002, 11:26 AM   #17
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Kinoshita - that is exactly it! good call!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-11-2002, 01:46 PM   #18
I've got an Extreme lathe (made by Hudy), it's got the bearings but I've never had a problem with it. With a diamond bit it cuts very smooth, and will give a nice shiney cut every time. I paid $100 for it used, then the bit was like $60-$70.
JeffC is offline   Reply With Quote
Old 07-11-2002, 05:19 PM   #19
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'm going to get the "V" groove plates and see it my lathe starts cutting like it did when it was new. I still would like to know how to take these bearing out. Sunday is my relax day so if I have too much time on my hands I might start to mess with the lathe and have it in tiny pieces...LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-11-2002, 05:36 PM   #20
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I've had my Hudy since late December, and have had no problems with the bearings, although it is still fairly new.
The only time it has had problems, is when the nut behind the controls got a little cut happy.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 07-11-2002, 05:49 PM   #21
Boomer's Avatar
STLN - there should be a screw that holds them in - on my Trinity lathe that's what it was. Just unscrew it (them) and the bearings should come out fairly easily.
Old 07-11-2002, 09:05 PM   #22
STLNLST's Avatar
I'll look for the screw this weekend.
Old 07-11-2002, 10:40 PM   #23
Moderator
Speedo's Avatar
They should be pretty obvious, they just come in perpendicular to the bearing face...When I got my Trinity I had to install them, Hudy's might be different...
Josh
Speedo is offline   Reply With Quote
Old 07-18-2002, 04:57 PM   #24
I brought the lathe and it works well but how do you determin what hight the tip shud be set at? Thanks Rick
Rick Draper is offline   Reply With Quote
Old 07-18-2002, 05:53 PM   #25
Trips's Avatar
Trader Rating: 16 (100%+)
The cutting tip of the bit should be a few thousandths higher than the centerline of the comm. It can be tough to determine on some lathes, but one trick is to put an armature in the lathe and take a small piece of scrap lexan and hold it upright between the bit and the comm. Slowly run the bit towrd the comm until it just "pinches" the piece of lexan and see if the lexan is dead upright, or wants to lean toward or away from the comm. If the height of the bit is correct, it will lean slightly toward the comm, away from the bit.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 07-22-2002, 03:51 AM   #26
What's everyone using to power the comm lathe? battery pack? 4, 6 cell? Power supply?
I really don't want to use packs. Got any leads on a power supply that puts out 4 to 5v? Thanks.
Sydewynder is offline   Reply With Quote
Old 07-22-2002, 04:44 AM   #27
I'm using a 4cell pack
Old 07-22-2002, 06:01 AM   #28
RC Nitro's Avatar
Sydewynder: Turbo 35
Rick, go to the Hudy site, Hudy.net all the tech and instructions are on the site. I have a Hudy on order. Waiting for Serpent to come back from vacation. I have a few Hudy tools and Excellent tire truer. I have found all their parts to be top notch.
RC Nitro is offline   Reply With Quote
Old 07-22-2002, 06:39 AM   #29
dtm
dtm's Avatar
Send a message via ICQ to dtm
4 cells on a 55T motor...
dtm is offline   Reply With Quote
Old 07-24-2002, 10:03 PM   #30
yodace's Avatar
I have a HUDY com lathe and was wondering what size the transmittion belt is?
yodace is offline   Reply With Quote
comm lathes BDRMBULLY Rookie Zone 5 05-03-2007 12:56 PM
Help with lathes?? TAMIYAMANUK Electric On-Road 28 05-01-2006 09:39 AM
lathes nitroburner65 Chat Lounge 1 04-02-2006 11:43 AM
2 lathes,T3 and TC4 graphite kit bigoTC3fan R/C Items: For Sale/Trade 3 06-16-2005 02:39 AM
3 racing lathes Brett.w Electric On-Road 3 04-21-2005 06:55 PM
