Team Orion Advantage Charger
#92
nope there is no mega flex on the 3rd step only the repeak
#93
Thanks for the help guys, I like the charger, but the manual was little to no help. I hope we keep this thread going with tips on different charge setups and what they give you for performance.
I'm interested in playing with different temp settings as well, I like the idea of the battery peaking at a cooler temp. Once it heats up for the summer, any ideas what temp you might set it at to peak for outdoor racing. I know even under a tent in the summer my batts always peak out a lot hotter than indoors during the winter.
racer-oZ
racer-oZ
#95
Problems with the Advantage
I just picked up one of these chargers this week and am having some problems. It charges great but, the motor run-in seems a bit problematic. I have some really fast stock motors that pull 10-11 amps during break in and the charger stops, stating there is a short circut/deadshort. On my prevous charger (LRP pulsar) this high amp draw was no problem but, the advantage seems very sensitive. Another big problem is that when I brok in a motor that drew 9-10 amps after about 1 minute the charger started smoking! I'm not sure if this is a manufacturers defect and I should send it back or if this is normal operation.
#96
Originally posted by berger
Ive bought one of these, hopefully ill have it soon, gotta go pick it up off a friend. The settings given above, are they a general one, how do you differ them for stock/19t/mod
#98
It is a question ow Whatts ! You just need to reduce the voltage to allow more amps to go in your motor !
I have no problem with a 8 turn, but I use 2,5 volt and RPM are more than enough.
#103
I just received my Team Orion Advantage Charger and after using it for a while here are a few questions:
1. Is the "step charge" mode setting a global setting? i.e. not specific/related to each "battery data" presets? I got a few different batteries with different capacity, it's a pain that i have to reprogramme it everytime.
2. Is the "tickle charge" and "repeak time" setting global? can i make it different for each battery data preset? i have NiCD and also NiMH batteries.. it would be a pain if i have to go back to the manual and disable (enable) tickle charge everytime i charge a different battery.
3. What does the "battery type" value really use for? i mean if we choose Ni-mh. what is the real difference compare to i set it to "NiCD". Now, please don't tell me it's for each battery type, i want to know HOW does the charger actually use this info to handle the charge/discharge differently, as we can set the peak detection and tickle charge value separately
4. Is it possible to find out what cause the charging to stop? i.e. peak detection, temperature above preset value or capacity reach preset value.
5. is the symbol that looks like "_|_" during the step charge mode means "mega flex"?
Hope someone can answer me this questions
#104
Re: Problems with the Advantage
#105
Has anyone experienced not being able to step charge a battery pack that has been trayed for awhile? After letting my batteries sit on a tray for a few hours the charger would not let me step charge my battery pack, but I could only use linear charge. I tried linear charging for about 1000 mah's and then tried step charging them and that still did not work. After linear charging the pack, I then ran the pack and after running the pack I trayed trayed the pack for about an hour I was able to step charge the pack then. Any help or suggestions on this matter would be greatly appreciated. Thanks!
