Team Orion Advantage Charger >
Old 02-23-2005, 08:10 AM
  #61
Paul
Also the voltage is starting progressively from 0 to the setup voltage in order to allow max amps to be used to spool up the motor, then the voltage goes up.
Since it is a max watt factor, the less volt you use the more amps are available
WorldCup2004 is offline
Old 02-23-2005, 08:36 AM
  #62
Lonestar's Avatar
Thanks for the reply folks, and especially on the lathe power Q (my T30 definitely takes too much space on my pitbox)... I somehow thought the MM and Orion internals were the same... ahem
Cheers,
Paul
Cheers,
Paul
Lonestar is offline
Old 02-23-2005, 09:44 AM
  #63
Paul,
you are welcome ! If you open them, you will see that they are totally different !
Have lot of fun !
Old 02-25-2005, 08:44 AM
  #64
Default Advantage and GP1100
Has anyone experience in charging GP1100 6 cells for micro cars ?
Thanks for any info
Old 02-28-2005, 02:59 AM
  #65
picco007's Avatar
Trader Rating: 97 (100%+)
Does this charger only discharge at 1 or 10 amps? Or is it adjustable from 1 -10 amps?
picco007 is offline
Old 02-28-2005, 06:39 AM
  #66
JMBetticher's Avatar
Discharge is adjustable from 1 to 10 Amps
JMBetticher is offline
Old 02-28-2005, 07:12 AM
  #67
picco007's Avatar
Thanks !
picco007 is offline
Old 02-28-2005, 09:25 AM
  #68
Rick Hohwart's Avatar
That is incorrect. Discharge rates are 1 OR 10 amps.
Rick Hohwart is offline
Old 02-28-2005, 09:47 AM
  #69
That's right. Sorry Picco007 !
Old 03-01-2005, 11:50 PM
  #70
Any experience with step charging the GP1100 packs ?
Old 03-02-2005, 04:08 AM
  #71
chaini's Avatar
Default New Pic
Hi guys
I've got here a new pic from the orion charger:
chaini is offline
Old 03-03-2005, 03:32 AM
  #72
jland's Avatar
Trader Rating: 80 (100%+)
Default 4 cell charging?
Has anyone tried this charger for 4 cell 12th mod? Any good settings for that? I see the ones for 6 cell but charging 4 cells is alittle different.
jland is offline
Old 03-03-2005, 04:02 AM
  #73
Eirik's Avatar
Jland,
Should be no problem using the 6cell step charge setups, the Delta Peak is only 3mV so that will not cause any problems!!
Eirik is offline
Old 03-03-2005, 05:46 AM
  #74
With the GP1100, if you use it in Micro cars, you can also use step charging for more power :
Step 1 : 500mAh 3A no flex
Step 2 : 550mAh 0.1A no flex
Step 3 : 1300mAh 2A 3mV/cell temp. 45
- You will have more power
If you use it as receiver batteries (5 cells/ 6V) :
Mega Flex (10ms) / 2 A
- You will hurt less the cells and have more "runtime"
Old 03-04-2005, 08:21 AM
  #75
racer-oZ's Avatar
I wish the manual gave more insight on charging setups for the step charge. I got mine yesterday and am trying to figure out what it means when it asks me on each step whether I want the impulse on/off? What does the impulse setting mean in the step charge setup menu? Do I want it on or off and what does it do?
Thanks for any info as I am practicing today for a big event this weekend and would like to try out the step charge feature. I am going to try the step charge setup posted earlier on this thread and see how it goes. Anyone have a good step charge setup for stock racing?
racer-oZ
racer-oZ is offline
