Team Orion Advantage Charger >
Old 02-22-2005, 10:17 PM
  #46
POOKYT's Avatar
I just looked online at Ultimate Hobbies and I didn't find the charger even listed. Did you guys call them or am I missing something in their website? Thanks
Brant
POOKYT is offline
Old 02-22-2005, 10:24 PM
  #47
ghoppa's Avatar
Trader Rating: 63 (98%+)
Brant
Pookyt,
your best bet is to call them!!!!!
granted, they don't have the best "updated" website in the sport, they DO have some of the best $$ on the west coast, let alone one of the largest inventories (of the "good" stuff) for the Racer.....
call them I saw 4 of them in their showcase on Saturday.......
ghoppa is offline
Old 02-22-2005, 10:27 PM
  #48
POOKYT's Avatar
Thank You sir!! I will call them tomorrow.
Brant
POOKYT is offline
Old 02-22-2005, 11:32 PM
  #49
It the new Advantage the SAME as the T-Much More Cell Master??
MARKANO is offline
Old 02-23-2005, 12:08 AM
  #50
JMBetticher's Avatar
No, it's not the same.
Top 3 positions at the TITC in the modified class used the Team Orion Advantage charger.
Atsushi Hara, Surikarn, Marc Rheinard and Andrew Moore were all happy by the performances of the charger.
JMBetticher is offline
Old 02-23-2005, 12:23 AM
  #51
Wink
I agree this charger looks really cool. Need to save up money.
newbee_racer is offline
Old 02-23-2005, 12:26 AM
  #52
The Team Orion Advantage allow you to run-in the motor as well.
The max Amp is 10 amp. You can run-in a 6 turn motor.
As the max instant Amp draw is 10 amp, if your motor use more than 10 amps, reduce volts on the charger and reduce timing on the motor.
For example, you can easy run-in a 6 turn motor at 2V with 0 timing.
You can delay the charge (Auto start) in Linear and Megaflex mode up to 99 minutes.
Old 02-23-2005, 12:42 AM
  #53
Do you have this charger? How do you like it and how much did it cost?
Old 02-23-2005, 12:56 AM
  #54
quote:
Originally posted by madjack
Ultimate Hobbies had the charger for 159.99 US
it's 159.95 and they still have them in stock,
WorldCup2004 is offline
Old 02-23-2005, 02:09 AM
  #55
silver_spo0n's Avatar
sorry but i'm don not know any thing about these things but i am very eager to learn.
run in feature? its like a motor dyno? what's the use?
thanks..
silver_spo0n is offline
Old 02-23-2005, 02:17 AM
  #56
cooliomojo-CEBU's Avatar
pareng red neck racer,
the run-in feature will allow you to run a motor through the charger.....its not like a dyno. a dyno measures the capabilities of the motor.....
with a run-in feature, you can run a lathe or break-in a motor....
common in the phils. with a run-in feature is the lrp pulsar competition grade chargers......
the lrp however crudely measures the performance of the motor since it can gauge the amp draw of the motor while you are breaking in the motor
cooliomojo-CEBU is offline
Old 02-23-2005, 02:41 AM
  #57
It allows you to run-in the motor (when you put new brushes for example).
With one unit, you can :
- charge your batteries,
- discharge your batteries
- use it as a break-in machine for your motor
- use it for powering your comm lathe
- use it for powering your tire warmer (7.2V for maximum 60minutes allow you to warm your tires at around 45)
- use it as a stopwatch
Of course, you can do more tricks on your motor with a MPM (Team Orion Motor tester).
But when you don't have too much money to spend on a charger and a motor tester, this unit is what you need.
Old 02-23-2005, 05:39 AM
  #58
For the users of Dead-Short or if you leave your battery on the tray overnight, the voltage of your battery will be very low. With the charger you have a protection, so the charger will firstly charge at 0.1 till 5V during 3minutes.
It will allow your battery to recover the normal voltage above 5V. Then after 3 minutes, the charger will tell you "Check"
Your battery has now reach voltage above 5 volts.
Now you can start the charge as usual (but if you use step-charging, do not response yes at the question "discharge before use ?")
Procedure when using battery that have been dead short or leave overnight on a battery tray :
- Charge as usual (the screen will show 0.1A and 5V) for 3 minutes
- After 3 minutes, The charger will tell "Check"
- Now your battery has reach voltage over 5V
- Now your battery is ready to be charge Linear, Megaflex or Step
Old 02-23-2005, 05:52 AM
  #59
Lonestar's Avatar
Trader Rating: 14 (100%+)
Salut Jean-Marc
Good to see you here too... And glad to see the Advantage finally reached Switzerland
Couple of quick Q's:
-What's the max amp draw it can sustain (just wanna check I can power my lathe, especially at initial spool-up)?
- Why does the cell-master not figure the run-in feature, whereas the Orion does?
Thanks!
See you saturday at the Peak race
Cheers,
Paul F.
Lonestar is offline
Old 02-23-2005, 06:31 AM
  #60
Hello Paul,
- Max amp draw is 10 amps. The basic set-up i use to powered a lathe is 3-4 volt max. So you have enough amp as i don't think you use a 6 turn to powered your lathe. The initial spool up is smooth as well.
- Of course because it's not the same.
See ya!
