Team Orion Advantage Charger >
Old 05-28-2007, 10:19 PM
  #421
Big B's Avatar
Originally Posted by curious mind
hi guys, ive been using my orion advantage for quite sometime in all my racing and Tx packs. and it charges better han my previous charger. But now im planning to get some of those lipo packs. i know the orion can charge lipo bats, but what about balancing? doe it software balance the batts while charging? sorry the manual does not say anything about it. tnx in advance.
Not to speak out of turn here but you need a balancer such as the Team Orion Stability Balancing System ORI62204, but from what I have read if you are planing on using the Orion 4800 or 3200 they dont need to be balanced, now the guys here can either validate that or disregard it
Big B is offline
Old 05-29-2007, 12:06 AM
  #422
curious mind's Avatar
Got this info from other thread, "Although Team Orion states that you dont need to balance charge their cells,
you will greatly improve your performance and longevity when balancing your packs during non-race days."
Will be ordring this balancer from orion in our LHS.
Thanks for the reply Big B. happy racing.
curious mind is offline
Old 07-28-2007, 05:31 AM
  #423
Island Losi's Avatar
could i use a 12Amp power supply to run with charger? im only using it for the charger.
Island Losi is offline
Old 07-28-2007, 01:12 PM
  #424
Trader Rating: 17 (100%+)
yes 12amp is sufficient.
Engtat
EngTat is offline
Old 07-28-2007, 09:20 PM
  #425
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Is there any way to get the carbon to charge th 2500 mah 3 cell lipo I bought to use in my transmitter?
andrewdoherty is offline
Old 08-17-2007, 09:24 AM
  #426
D Hunt 3's Avatar
bump...need to know if transmitter lipos can be charged on these.
D Hunt 3 is offline
Old 08-24-2007, 12:09 AM
  #427
larlee's Avatar
what does "ohm" refers to on the charger?
i have checked both of my cells and it says 143 ohm, what does that means?
larlee is offline
Old 10-18-2007, 06:46 PM
  #428
Burlap's Avatar
I'm looking at cycling some 4200 cells that I haven't used for a couple of months. Is the default setting shown in the manual for cycling (1amp charge/10amp discharge) fine for the 4200s or should I give it a higher amp charge? And how many cycles should I do?
Burlap is offline
Old 11-11-2007, 06:17 PM
  #429
MikeXray's Avatar
Trader Rating: 73 (100%+)
My charger decided to stop working today, It acts normal, but will not give any current for charging, discharging or motor run in. Anything I can try before sending it back?
MikeXray is offline
Old 11-11-2007, 07:07 PM
  #430
Moderator
pc9840's Avatar
Default Stopped working
The samething happened to my charger yesterday at the track. No current when charging. I changed profiles, charge current, packs, and power supplies. I also tried power cylcling the charger 10 times to reset the software. A couple guys at the track said to try that, although I am not sure if it actually reset anything. I didn't see anything change. I am charging orion 4800 LiPo's and they charged fine on my buddies advantage.
pc9840 is offline
Old 11-12-2007, 12:26 PM
  #431
Tech Legend
Wild Cherry's Avatar
Default Advantage Charger set-up problem
I had the same problem yesterday, I could not enter my cell count for Li-Po ...
On Nk-Ml or Ni-CD no problem changing the cell count ....
Please
What am I doing wrong ?
Wild Cherry is offline
Old 11-12-2007, 07:10 PM
  #432
Moderator
pc9840's Avatar
Default Charger
MikeXray -- I contacted orion and was told to just send the charger in.
pc9840 is offline
Old 11-12-2007, 07:25 PM
  #433
MikeXray's Avatar
Thanks, I'll have to do the same.
MikeXray is offline
Old 12-13-2007, 08:59 PM
  #434
MikeXray's Avatar
I sent mine in and got a brand new one back in about a week and a half, excellent service, thanks!
MikeXray is offline
Old 12-15-2007, 03:52 PM
  #435
will one of the novak purple power supplies power two of these at once?? I am just going to be charging 4 cell packs at 5 amps a piece?
punkracer24 is offline
