Old 10-15-2005, 03:21 PM   #361
hmmmm,
my orion has done the same thing as cyrrus. i charged some batteries last night and this morning it says check battery.
josh69162, the pitbulls are the best little charger i owned so far. the earlier blue case does not have any extra features but i used two of them for two years and never gave me a problem. the orion finally let me down. i thought i had a good one. oh well. i did pick up the pitbull X3 a few months ago. one warning. do not repeak with a pitbull unless you are watching it. it will automatically prevent false peaks during the first minute. if your battery peaks during this time it will keep charging.
baih is offline   Reply With Quote
Old 10-21-2005, 09:41 AM   #362
Bluecow's Avatar
Default hara
I hear that their is a Hara version of this charger coming out !
anyone have more info on it ????
thanks
Bluecow is offline   Reply With Quote
Old 10-21-2005, 10:00 AM   #363
i sent mine in for repair last monday and a new one was delivered on wednesday. i do live close. thanks rick
Old 10-26-2005, 08:51 AM   #364
diha's Avatar
Default GP3700
Hi,
Anyone got a good setup for GP3700 match cells to share?
I had been using step charge with the following value:
STEP 1..... 200mah 0.7amp
STEP 2..... 2700mah 5.5amp
STEP 3..... 4600mah 5amp
cut of 3mv/cell; temp 50 degree.
diha is offline   Reply With Quote
Old 11-08-2005, 01:13 PM   #365
TFR
TFR's Avatar
Is the discharge mode on this charger discharge from '1 to 10 amps' or '1 or 10amps'?
How does the motor run in work? Can I set the amount of volts goes to the motor? What result does it display?
Thanks.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 11-10-2005, 07:05 AM   #366
The new Advantage charger is on the orion site it has a carbon case and charge lipo as well !
WorldCup2004 is offline   Reply With Quote
Old 11-10-2005, 04:38 PM   #367
Phil C's Avatar
TFR,
The discharge is 1 OR 10 amps.
The motor run in allows you to set the voltage and time and it displays the amp draw of the motor.
This is a little off topic but hey, what paint did you use to get that very bright flo pink on the shell in your avatar, assuming that is your shell
Cheers Phil.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 11-14-2005, 11:23 AM   #368
diha
on the team orion homepage you can see lot of set up for the GP3700's
Nicolas is offline   Reply With Quote
Old 11-14-2005, 12:05 PM   #369
gee-dub's Avatar
2 questions, apologies if this was answered ealier in the thread (did not find anything).
1. the new lipo compatible advantage charger, is this made by much-more racing? it seems similar to the cell master.
2. any word on availability of the new advantage charger (i googled the part # from orion's site on google and only a few r/c message boards and orion's site came back)?
thanks in advance.
gee-dub is offline   Reply With Quote
Old 11-14-2005, 12:29 PM   #370
I have found the part number for you and from what I know it is not made by much more.
All Team Orion products are designed from the ground up, by racers for racers. This philosophy allows us to come out on top against the strongest competition while at the same time providing the best equipment for every level of racer and hobbyist. From the track to the backyard, we take battery charging in any application as seriously as charging our own World Championship winning V-Max Plus RDS cells. Team Orion has spent over a year of research and development with our team of designers, engineers, and our World Championship winning drivers such as Atsushi Hara, Marc Rheinard, Surikarn, and David Spashett, to bring you the charger you now see before your eyes.
The very popular Advantage Charging system has been updated with a new, high tech carbon fiber look case with charging function specifically for LiPo (lithium polymer) battery packs.
Charge 1 to 8 cells
50 to 5400 mAh NiMH and NiCd
batteries at 1 to 10 Amps
11 to 15 volts D/C input
Customizable Linear, Flex and Step charging
NEW LiPo charge function
5 charging memories
Battery cycling
Discharge at 1 or 10 amps
Input and output short circuit
Protection
Attachable battery charging tray
Full motor run-in feature
Powers commutator lathes
Full manual lap counting functions and displays: time elapsed, average lap time and number of laps
Indigo Blue backlight 2 x 16 characters display
Customizable user name
English, German, French and Japanese displays
Easy to navigate, 4 push button settings
Choice of 3 different alarm tones or silent function
Silicone output wires
Built in Clock
High tech carbon fiber look case
ORI30117 Advantage Charging System w/LiPo Capability
Old 11-24-2005, 09:00 PM   #371
hey guy's fianlly with much strain and may phone calls finally got my charger back. not Orion's fault, but rather the distributor in Toronto. left it in the warehouse with out intrution then another thing . when I called them and finally solved the problem. Got them to ship it over night.
now my question, is I lost all my setting.
what would be a good setting for both 4 cell pack and 6 cell packs. 33oo.
not to sure if it would be a differnce in the setting for each. but your guy's hellp would be great.
cyrrus is offline   Reply With Quote
Old 11-28-2005, 10:30 PM   #372
Aparatchik's Avatar
Just picked one of these up and have been playing with it tonight, getting used to the UI (somewhat in need of help), and its features. One quick question: using step charging, should I set the battery data for my 3300's to something higher than that? It seems that the charger cuts off based on either total mAh (as determined by the battery data), deltaV or temp? What sort of values (V, mAh, temp) should I see when a 3300 1.17 pack is successfully charged?
Aparatchik is offline   Reply With Quote
Old 01-10-2006, 04:00 PM   #373
TFR
TFR's Avatar
Anybody using the new carbon case Advantage yet?
Old 01-11-2006, 07:02 AM   #374
kewdawg's Avatar
I would, if, I knew where to buy one.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-24-2006, 10:52 AM   #375
Is it possible to turn on the delta peak monitoring for the first stage when I use stepcharging?
I fried one battery the other day... I was sure that it was discharged but I was wrong . When I realized what is going on the battery was heavily overcharged its temperature was more than 100C and weird noises came from of the cells like ssspppfff pffshhhs . I know that I should connect the temperature sensor to avoid this failure but I just forgot to do so. The delta peak monitoring would be an error proof solution...
cvt01 is offline   Reply With Quote
F/S Team Orion Advantage Charger dragracer72nova R/C Items: For Sale/Trade 5 05-31-2008 12:36 PM
team orion advantage charger lorider75 Radio and Electronics 2 03-24-2008 09:19 PM
Team Orion Advantage Charger J_Longbrake R/C Items: For Sale/Trade 10 12-06-2007 08:09 PM
New Team Orion Advantage Charger Benro Electric On-Road 4 11-14-2005 11:09 AM
Team Orion Charger ( The New Advantage) BCOLEMAN R/C Items: For Sale/Trade 0 04-18-2005 01:22 AM
