Team Orion Advantage Charger >
Old 02-22-2005, 01:00 AM
  #16
Eirik's Avatar
Hello JMB,
How are you? have not heard from you in a while......
Anyway, I used this setting for my GP3300 this weekend, worked really really good!!
Step 1 : 2500mAh 7A - Mega Flex off
Step 2 : 2550mAh 0.3 - Mega Flex off
Step 3 : 3950mAh 4A
Temperature : 47°
Delta Peak : 3mV
Eirik is offline
Old 02-22-2005, 01:08 AM
  #17
JMBetticher's Avatar
Hello Eirik !
I'm fine thanks !
That's cool ! Keep on going !!
Greetings from snowy switzerland...
JMBetticher is offline
Old 02-22-2005, 01:18 AM
  #18
rocketron's Avatar
Trader Rating: 16 (100%+)
Does anyone know what the IMPLUSE on/off does or is? it is a variable on stage 1 and 2 of the step charge.
rocketron is offline
Old 02-22-2005, 01:38 AM
  #19
It's the mega-flex charge.
Using mega-flex charge, it hurt less the battery and battery life will be increase.
Old 02-22-2005, 01:54 AM
  #20
rocketron's Avatar
any place to read or understand what that charge type is doing. Seems like some type of pulse charge - yes/no?
Will there be software upgrades made available for tis charger? I saw annoucement or something that made me thinl that there maybe upgrades at some point?
thx
Old 02-22-2005, 02:00 AM
  #21
Eirik's Avatar
I have tested a litle with the Megaflex and it generates less heat, increase runtime a litle, but with a litle less power overall..... Should make the cells last longer as well, perfect for practice and club racing!
For serious racing, the step charge is the new standard, amazing performance!! and it also hurts the cells less than with normal linear charge......
Eirik is offline
Old 02-22-2005, 02:04 AM
  #22
rocketron's Avatar
understand step charging and agree been using it for a long time with other chargers that offered step.
but is megaflex just a version of pulse charge? yes/no
i like the charge from this charger from the last week of working with it and two days of use.
thanks
Old 02-22-2005, 02:08 AM
  #23
Mega-Flex is pulse charging with negative puls
On the advantage, you can adjust the negative pulse. The longer the pulse, the stronger the effect. (page 24)
Old 02-22-2005, 02:40 AM
  #24
Default MegeFlex Advantage Charger
Mega Flex charging is a technique applying a reverse pulse during charging. On the Advantage charger this pulse can be adjusted from 5 ms to 20 ms.
The idea beind the discharge pulse is to redirect the migration of oxide gas away from the reacting plates, preventing oxidation, allowing the battery to prolong its life and capacity.
The results show improved charge input and output, lower heat generation during charge. The Mega Flex charging consumes gas bubbles generated during charge at the positive and negative electrodes. Removing bubbles increases the effective electrode surface area, results in a lower charge overvoltage and reduces cell pressure.
So the track testing of Eirik are correct ! More punch with Step Charging, more battery life with Mega Flex !
WorldCup2004 is offline
Old 02-22-2005, 03:53 AM
  #25
Old 02-22-2005, 04:02 AM
  #26
Anders Myrberg's Avatar
Default Re: MegeFlex Advantage Charger
A lot of gas and bubbles here...
Is this before or after eating the beans?
Anders Myrberg is offline
Old 02-22-2005, 04:21 AM
  #27
John Doucakis's Avatar
Anders Myrberg-
John Doucakis is offline
Old 02-22-2005, 06:39 AM
  #28
Default MEGA FLEX
JMBetticher what are your experience using the Mega Flex vs Step and have you tried to include Mega Flex in the step charging ?
Old 02-22-2005, 07:14 AM
  #29
Step charging will provide excellent punch. The cells will generate less heat during the discharge and internal resistance will be lower.
Mega flex will provide more runtime with less punch. Like Eirik say, perfect for club race or leisure.
Old 02-22-2005, 07:25 AM
  #30
Martin Crisp's Avatar
Default middle step
Hi,
What is the purpose of step 2 at such a low amp for about 50mah. Is this to also increase battery life?
Hye,
Atsushi Hara and Marc Rheinard used the Team Orion Advantage charger at the TITC 2005.
They used step charging.
Here is the set-up they used:
Step 1 : 2400mAh 7A - Mega Flex off
Step 2 : 2450mAh 0.2 - Mega Flex off
Step 3 : 4200mAh 6A
Temperature : 50°
Delta Peak : 3mV
Give a try and have fun !!
Martin Crisp is offline
