Team Orion Advantage Charger >
Old 04-02-2005, 01:29 PM
  #166
Crashmaster, those settings you gave raving-monkey, are they for Gp3300??
crangon is offline
Old 04-02-2005, 01:47 PM
  #167
Crashmaster's Avatar
Yes mate, they are. I've been trying it and it seems to give amazinging power with the cells taking around 3600 mah. They came from Hara apparently.
Cheers
Crashmaster
Crashmaster is offline
Old 04-02-2005, 02:11 PM
  #168
Thanks for the reply I know what I will be trying this weekend.....!
crangon is offline
Old 04-02-2005, 10:13 PM
  #169
Trader Rating: 14 (100%+)
Ultimate Hobbies has the best price.
sdmlsu1 is offline
Old 04-02-2005, 10:54 PM
  #170
Guo Chean's Avatar
i have a problem that i set 3 different battery in 5 charging mode and i also save different step charge mode. but 1 thing is when i using my 3300 step charge mode after i finish charging. i want to charge my 3600 and i change the charging mode but when i go into step charge it still can see the 3300 step charge mode. so how to solve this problem. thanks
Guo Chean is offline
Old 04-05-2005, 12:58 AM
  #171
JMBetticher's Avatar
Check this out :
http://www.teamorion.com/news.asp?id=420
JMBetticher is offline
Old 04-05-2005, 01:01 AM
  #172
Guo Chean :
You can set 5 different batteries, linear etc but Step Charging has one setting.
Old 04-05-2005, 01:25 PM
  #173
Guo Chean's Avatar
Originally posted by JMBetticher
Guo Chean :
ok thanks man! i though i same with the 5 mode memory.
Old 04-06-2005, 12:31 AM
  #174
kewdawg's Avatar
Originally posted by ghoppa
quite a few are selling it....
Ultimate (possibly your best price)
Stormer
Sheldons
etc.....
Ultimate doesn't carry it and Stormer has the 1st version. I'm hearing, it's not avail. in the states, yet. "Too new.", seems to be the popular phrase. I'll check with Sheldon.
kewdawg is offline
Old 04-06-2005, 02:00 AM
  #175
rocketron's Avatar
Trader Rating: 16 (100%+)
you are looking for the Orion Advantage charger right? if so i know Ultimate has several in stock - i was just there tuesday evening. i think.... it was 159 or 155
rocketron is offline
Old 04-06-2005, 02:02 AM
  #176
kewdawg's Avatar
No. The MPM2 (Motor Performance Manager 2).
kewdawg is offline
Old 04-06-2005, 02:06 AM
  #177
rocketron's Avatar
sorry - they had quite a few of the PEAK red MPM's and a couple older Orion's in stock. they probly want to sell them first
Old 04-06-2005, 02:07 AM
  #178
kewdawg's Avatar
Yeah, that's just great. Isn't it?
kewdawg is offline
Old 04-06-2005, 07:08 AM
  #179
ghoppa's Avatar
Trader Rating: 63 (98%+)
Kewdawg......
correct me if I am wrong, but based on Orion's website the Motor Performance Monitor (V.2) is what I have, which is the one with the CTX option in it (yeah "RocketRon", the one you trained me on @ So-Cal about a month ago)....
I can almost bet my life that Ultimate, Stormer & many other ("for the Racer") Hobby Shops carry it.....You'll just have to make sure you "catch" them when they have it in stock...
My MPM V.2 has CTX as well as the "hard" button configuration....
hope this helps...
ghoppa is offline
Old 04-06-2005, 02:42 PM
  #180
kewdawg's Avatar
Kewdawg......
hope this helps...
The MPM 2 w/ CTX is the newer version of the motor performance manager. It looks different from the original, in color, button layout, etc. . I spoke to Ultimate and I was told they didn't carry it. They do carry the Peak Performance version, which is supposed to be the same thing. Stormer, also, only carries the Peak Performance model, which by the way, is cherry red.
kewdawg is offline
