Team Orion Advantage Charger >
Old 03-23-2005, 06:37 AM
  #136
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally posted by racer-oZ
crash, the instructions are not going to help you at all on setups. They merely show you how to navigate through the menu, but tell you nothing about setups or charging recommendations. I got my setups and stuff from some guys on here for the step charging function. I've used it a couple weekends now and thought the step charge was cool and seemed to help a little with punch, but unless they fix the motor run in problem before you buy one make sure you have another alternative for breaking in stocks and 19turns.
hope this helps
racer-oZ
Thanks racer-oZ. I have my 35BL for motor break in. Plus Billy does all my motors. All I do is put in the car run it give it back to him and say FIX IT, its too slow.
Looking forward to racing mod with you guys this summer at Fastlane.
Later,
CRASH is offline
Old 03-23-2005, 08:15 AM
  #137
Trader Rating: 14 (100%+)
Does this charger have a delay feature for charging so you can set it and walk away? (ex. set up charger to start charging in 15 minutes from present time)
sdmlsu1 is offline
Old 03-23-2005, 08:49 AM
  #138
rocketron's Avatar
Trader Rating: 16 (100%+)
yes it does but unfortunately not when using step charge function.
rocketron is offline
Old 03-23-2005, 11:42 AM
  #139
Default Step Charging
I'm assuming you guys are using step charge function on packs that have been zeroed on a tray. Will step charge work on a partially charged pack? I charge my trayed packs at 6 amps with 3-5mV delta and it takes about 35-40 minutes. How long does it take to charge a trayed pack using step charge?
sdmlsu1 is offline
Old 03-23-2005, 11:52 AM
  #140
rocketron's Avatar
Default Re: Step Charging
charger in step charge mode will charge your trayed packs. step charge of a partially charged pack.... would depend on your setup because the peak detection is locked out during step one and two so you could easily over charge, but with that said if your temp setting is set that would stop the charge by reaching temp.
step charging a trayed pack is taking me approximately 40-45 minutes
Old 03-23-2005, 11:57 AM
  #141
syndr0me's Avatar
Trader Rating: 32 (100%+)
Could they have made it any uglier?
I'm just sayin'... :-D
syndr0me is offline
Old 03-23-2005, 12:40 PM
  #142
Crashmaster's Avatar
You know what they say, its on the inside what counts
I've been running it now for a month, and I must admit I'm liking it very much. I haven't had any problems yet with the motor running-in feature, so maybe I'm lucky, but time will tell. The step charging method its brilliant, and I found it to offer tonnes for power with the runtime still intact.
Cheers
Crashmaster
Crashmaster is offline
Old 03-23-2005, 04:00 PM
  #143
POOKYT's Avatar
Yes they could have!
Brant
POOKYT is offline
Old 03-23-2005, 04:03 PM
  #144
CRASH's Avatar
Beauty is in the eye of the beholder. I will take perofrmance over beauty any day.
Later,
CRASH is offline
Old 03-23-2005, 05:47 PM
  #145
Does the charger use temp/mAh/delta mV cutoff protection for all of the different charge modes?
sdmlsu1 is offline
Old 03-23-2005, 09:19 PM
  #146
Trader Rating: 17 (100%+)
If I am not mistaken here, only step charge mode uses mah/peak/temp for cutoffs. Linear and Flex use mah/peak for cutoff.
429racer is offline
Old 03-23-2005, 09:52 PM
  #147
So you cannot use a temperature cutoff when charging in linear mode... now I may have to rethink my decision to buy.
sdmlsu1 is offline
Old 03-23-2005, 10:13 PM
  #148
Rest assured that the charger is a very nice charger. I have not yet peaked my batteries by temp but by mahs and peak in step charge mode.
429racer is offline
Old 03-23-2005, 10:20 PM
  #149
rocketron's Avatar
i've only used the step charge function but had thought the temp cut-off was available in the linear mode.
maybe one of the orion folks can help on this?
Old 03-23-2005, 10:24 PM
  #150
racer-oZ's Avatar
rocketron, i think you are right as well... the way i remember it was that if you wanted it to peak by mv then you set the temp cutoff high so the mv would detect peak before the temperature, and vice versa, but i'm far from an expert on this charger yet.
racer-oZ
racer-oZ is offline
