Old 06-08-2012, 10:06 PM   #1
vito's Avatar
Default play tires
i have a tc 6.1 kit need tires to play in the street that will last a few runs now and then?
vito is offline   Reply With Quote
Old 06-09-2012, 05:18 AM   #2
pejota's Avatar
Get some HPI X-Pattern tires. D-Compound or Pro Compound. Those will be good enough for your streets.
pejota is offline   Reply With Quote
Old 06-09-2012, 09:14 AM   #3
vito's Avatar
like to get a set of pre mounts
Old 06-09-2012, 10:47 AM   #4
vito's Avatar
need rims what size and off set. and do i need foam too in them?
Old 06-10-2012, 08:11 PM   #5
vito's Avatar
what rims to put the hpis xs on?
Old 06-10-2012, 08:27 PM   #6
Chaz955i's Avatar
HPI makes a nice selection of rims. Assuming just playing and not racing the offset can be about anything and work. Electric touring car race bodies are set up at 190 mm and many of the more realistic bodies HPI sells are 200 mm which would require some offset in the wheels to fill out the fenders. Making things even more complicated is some bodies are wider in the rear than in the front so the offset front to rear might be slightly different. Solaris tires might work good for you because they are pre-mounts and can be bought with a spoked rim which looks a little nicer than the dish wheels. They are designed as a race wheel and don't have much offset but if you are running a 190 mm body on your TC6.1 it should look good. For running outside one of the harder compounds should give you decent grip and durability. Sweep makes a good premount as well but to my knowledge only offers a dish wheel.
Good luck.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 06-10-2012, 08:35 PM   #7
vito's Avatar
a main has some pre mounts. like 96 hot and so on
Old 06-10-2012, 08:47 PM   #8
vito's Avatar
hpi has nice rims in like 26 24 mm. can i put them on a smaller rim an so on
Old 06-27-2012, 11:44 AM   #9
vito's Avatar
Old 06-27-2012, 08:27 PM   #10
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
36r premounts actually work quite well on the streets without prep.
valk is offline   Reply With Quote
Old 06-27-2012, 08:33 PM   #11
vito's Avatar
link iam new at on road got a new tc 6.1 kit
Old 06-27-2012, 08:48 PM   #12
macavant's Avatar
Trader Rating: 64 (100%+)
Check these out: http://www.speedpassion.net/shop/det...01&c=BODYSHELL
I bought them to just use as a shelf set - for the price they work really well. I even mounted them on my F103GT and the traction was surprisingly good. Best $6 set of pre-mounts I have ever purchased. Bought 2 sets - $18.58 shipped to my door. That's cheaper than a set of HPI rims alone.
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 06-27-2012, 09:03 PM   #13
valk's Avatar
http://www.amainhobbies.com/product_...s-92-Degrees-4
Old 06-27-2012, 09:05 PM   #14
vito's Avatar
thanks saw that but i dint know at the time
Proline Switch tires for SCT? diesel32x Electric Off-Road 9 03-21-2010 11:46 AM
What would you guys recommend for practice/play tires? Furadi Nitro Off-Road 14 04-24-2008 10:30 PM
