Old 06-05-2012, 06:24 PM   #1
Default Battery for newbies to this hobby
Hi guys, I m new to this hobby. I have a HPI E10 Ford GT with a battery that cant hold its charge. Its a HPI RACING 7.2v 1500mha Ni-Cd. it only last about 10min.
I don't need to increase the performance for now as I still cant control the car well enough at current speed. All I want is longer play time, pls advice what battery should I get.
Thanks.
Denniskee is offline   Reply With Quote
Old 06-05-2012, 06:30 PM   #2
Suspended
Exclamation
The battery is fine at 10 Minutes runtime. Try to get a 4600mah smc energ nimh pack for better Performance....
bertrandsv87 is offline   Reply With Quote
Old 06-05-2012, 06:35 PM   #3
Trader Rating: 49 (100%+)
With that size battery, about 10 minutes is all you can expect for it to last. It's not that the battery isn't holding its charge, you are using the charge up. If your speed control is capable of handling a lipo, and you can afford a lipo and a charger, then I would get a Gens Ace Lipo (can be had for around $20... Sky Lipo or Blue Lipo will work just as well for playing around and are cheaper) and a lipo charger that will charger around 5amps (Thunder Charger or similar cheap lipo charger).
http://www.hobbypartz.com/77p-sl4000...-hardcase.html
http://www.hobbypartz.com/77p-sl5000...-hardcase.html
Charger:
http://www.hobbypartz.com/thac6smbachw.html
With a 5 amp charger and 2 batteries, I think you'd be more than pleased, especially compared to what you have now. You can recharger one battery while you run the other. Should get runtimes of 20 minutes or more depending on how you are running the car.
If you need to stick with NIMH or NICD, check these out. That way you already have a charger to charge them if you don't have a lipo charger.
http://www.hobbypartz.com/98p-5000-7...ble-stick.html
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4621 12-02-2017 09:30 PM
Hobby Habit Indoor - Adelaide v0rtex Australian Racing 4622 08-22-2016 05:06 AM
TECHNOLOGY AND NOT BEING ABLE TO TUNE A NITRO IS TAKING THE HOBBY TO ELECTRIC bubbafrc Electric Off-Road 48 09-16-2011 10:58 AM
Behavior in this Forum futureal Electric On-Road 48 02-20-2005 01:55 PM
