Steel Spur and Motor Flex >
Old 06-07-2012, 03:32 PM
  #16
Satyrisci's Avatar
Originally Posted by UK.hardcore
Its not hatin', its common sense, TT01 is not made for powerfull systems.
it will keep breaking down forever.
Satyrisci is offline
Old 06-07-2012, 07:44 PM
  #17
Will27's Avatar
Originally Posted by sosidge
If you are going to continue using fast motors, you need to upgrade a few parts - or change to a better chassis. The TT-01 suits a silvercan motor, but more power than that is beyond the limits of the chassis.
+1
I know someone who had a TT-01 with a 3.5T(before Lipo batteries). He had spent a whole load of money upgrading the plastic parts so it didn't strip something everytime he thought of touching the throttle, and then the back half of the diff casing ripped off the chassis because of the diff being forced away from the connecting gear under power.
It will be much cheaper in the long run to buy a car that can handle the power.
Will27 is offline
Old 06-08-2012, 03:45 PM
  #18
Satyrisci's Avatar
I'm not quite sure how to respond to that ridiculousness. Here are 2 ideas
I'm glad I learned to take what I find on the internet "with a grain of salt"
Secondly,
Old 06-09-2012, 01:57 AM
  #19
UK.hardcore's Avatar
When guys with a decade of experience tell you is not worth it, you don't care.
fine, contunue the fun of breaking the car every run.
UK.hardcore is offline
Old 06-09-2012, 08:04 AM
  #20
heretic's Avatar
Dude you have no idea how much you are making a fool of yourself, being so arrogant after asking perfectly good advice for your supermarket car. The TT01 can handle a silvercan-ish motor for 24hours non stop, it's been done, but anything more than that is asking for trouble.
Now bookmark this page, and come back in a few years to apologize.
heretic is offline
Old 10-05-2013, 07:16 PM
  #21
I never saw the second page of this thread till now. These comments are hilarious. My TT01 has a 5.5T in it with nothing but upgraded bearings. I have ran it on a 6000mah 25c 2S battery for 50+ runs topping it out at 44MPH on stock gearing. Its been a resilient car. The only thing I have had to replace is a rear arm/shock when my crappy 15 dollar servo wouldnt center and it hit a car tire at almost full speed. Also... years of experience only go so far in this hobby. Most of this stuff has not been out that for that long.
RainStryke is offline
Old 10-06-2013, 07:31 AM
  #22
Airwave's Avatar
You don't put grease between the pinion and the spur gear right? It would be a very bad idea to introduce grease there...
Airwave is offline
Old 11-13-2013, 02:40 PM
  #23
Satyrisci's Avatar
Right. It needs to be dry in there.
Old 11-13-2013, 03:34 PM
  #24
Lessen's Avatar
Originally Posted by RainStryke
It never broke down in the first place, the assembly was wrong if you read what he posted. It was the wrong bearing, allowing that flop which made the spur gear move and mesh against the pinion sideways, tearing away at part of the spur gear.
So... it broke down.
Lessen is offline
Old 11-17-2013, 07:41 AM
  #25
Satyrisci's Avatar
The problem was incorrect assembly. Operator error. Not the car's fault.
