Old 05-03-2005, 05:04 AM   #106
RayWarner's Avatar
Send a message via AIM to RayWarner
Yep that avatar loks great!!! Where do all the team members race? And what do you all race? Right now, when it warms up, I will be racing electric mod. foam asphalt. Here in Illinois. Ray
RayWarner is offline   Reply With Quote
Old 05-03-2005, 05:56 AM   #107
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
Running Nitro Touring right now here in North Carolina.
[url]http://www.thercspeedway.net/[/url]
jt6 is offline   Reply With Quote
Old 05-03-2005, 10:50 AM   #108
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
I will be running Mod Nitro outdoor and practicing with my electric touring on carpet working on tire setup....Speaking of which what have you guys found works? I've talked to Jospeh and he gave me some suggestions, but just wondering from other drivers...
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 05-04-2005, 05:08 AM   #109
RayWarner's Avatar
It seems that black/gray and gray are the starting choices. Let us know what you find out. Rat
Old 05-04-2005, 05:26 AM   #110
alb
Trader Rating: 19 (100%+)
On a fresh track, run Red, Red/Magenta. When the traction comes up switch to the Black/grey combo.
alb is offline   Reply With Quote
Old 05-04-2005, 09:15 AM   #111
litespeed-dom's Avatar
I have done A-B testing with Black, Black/Grey and Magenta, Mag/Red. I've heard comment that the Mag/Mag/Red combo is too stuck. I can say if you run 19T or stock foam, that would be the case, but not for Mod. I'd done about 3 A-B test on 3 different days, different traction on the rug. Mag/Red definitely has an upper hand on the Black/Grey when it comes to Mod. One thing too is that I found (along with my Jaco 1/12th tries) is that a lot of people think harder tires will wear less, that is not the case with these tires. Black/Grey seems to wear a little faster then Mag/Red, and it just lack that steering I'm looking for. And A-B test shows I'm at least .2 sec quicker with the Mag/Red. If the traction comes up drastically, like Snowbirds, I would venture to Black/Grey.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-04-2005, 09:27 AM   #112
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i bet the higher wear on the blk/grey comes from using more steering to make up for the loss of front bite...
the only ones i have used were the mag-red/mag set on a med bite track, and it worked well for me, with hardly any wear...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-04-2005, 09:36 AM   #113
TigeRyan's Avatar
Are you guys using Paragon or some other traction compound??
Old 05-04-2005, 09:42 AM   #114
Well, during my A-B tests, I leave my setup the same, my radio trims same. The only thing different is a different pack of batts, different time of the day. Not just the front, but the Grey rears wear quicker then Magenta. When I used a durometer on the tires, the shores are pretty accurate on the Mag, Mag/Red as it states on the labels, the Black, Blk/Grey are about 5 higher than what the labels state. I believe it's a different make of compound too, not 100% sure about that though.
I use TQ Red.
Dom
Old 05-04-2005, 12:30 PM   #115
TigeRyan's Avatar
How about on your Mod Nitros, I've run a 37 rear with a 40 front, does that combo seem to hold true with the GQ tire?
Old 05-04-2005, 12:36 PM   #116
40/37 is a real good start. Once thing I do notice is that, my GQ 1/8th tires are lower wear then others, but it does require a couple of laps to get the tires warmed up. So be careful out there on your first 2 laps, don't push too hard.
Dom
Old 05-04-2005, 12:58 PM   #117
TigeRyan's Avatar
I've tried tire warmers on my foams before you think that might help on the mod nitro, cause there is nothing worse then a loose mod nitro
Old 05-05-2005, 07:58 PM   #118
GMartinez's Avatar
Trader Rating: 85 (100%+)
710, what traction compound are you using in mod nitro on the tires? Also what compounds are you running, I run on a parking lot track that is usually pretty low traction so it sounds like we run on real similiar surfaces...
I tested the 37 shore all around @ Jackson Raceway new sealed track that only had two events track was stilll very green & traction compound was sprayed since it rained early before the races began car had a lot of front bite & great on power steering I am running a 710 with a front oneway locked so it might be a little different on your car. Rear traction was decent not cause of the tires but when I made some chages the car was dialed.
@ the second track I pass a set to two team mate's who run's the same car @ a track in Middletown very rough like parking lot stlye with a lot of divets we trimmed a mm off to ensure even tire wear for the 15 minute A main Booth car's looked way more planted then other cars. Getting into the final minute mark booth car's had the same traction but the other racers who ran nitro shoes lost traction & at the end comparing the Gq to the Nitro shoes & Ellegi's there was a lot more tire left on the GQ'S & almost no tire left on the Nitro shoes & Ellegi's booth brands give plenty of traction but the Gq outlasted in tire wear.
I will give more info as I will be in CT racing www.rcmadness.com trophy race an awesome track with no traction since the last three weeks of no racing due to rain. & also the 35 shore works great testing was done on a MTX3 prospec instantly dialed on a rough track. So good luck to all the Team drivers & looking forward to more A main winnings from everyone
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 05-05-2005, 08:02 PM   #119
GMartinez's Avatar
Hey can we get a link to look at the track pic's
Old 05-05-2005, 08:05 PM   #120
TigeRyan's Avatar
I'll be heading to Jackson in 2 weeks for there Trophy race, you heading there???
Milwaukee 2.4v power driver with batt and charger... High quality driver. PIC INSIDE SCUBA STEVE R/C Items: For Sale/Trade 14 01-24-2008 09:42 AM
Sponsored driver SELL OUT!!! Tannerb R/C Items: For Sale/Trade 52 01-15-2008 06:58 PM
Who is the oldest sponsored pro driver in R/C? speedemall Chat Lounge 24 10-14-2007 02:39 AM
2nd Annual RC Driver Sponsored Race of Champions... The Joker Nitro Off-Road 9 07-10-2007 06:18 AM
