Old 02-15-2005, 07:32 PM   #1
Default TL-01 adjustment
How do i adjust the camber on the front of my TL-01, have looked but cant suss it out
any help would be great,
Cheers
robborc is offline   Reply With Quote
Old 02-15-2005, 07:36 PM   #2
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
If I'm not mistaken, the TL-01 comes with a preadjusted camber that really isn't necessary to change.
They are fixed links and cannot be adjusted. You would need adjustable camber links like there:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJ56&P=7
Paul_TC4 is offline   Reply With Quote
Old 02-15-2005, 07:52 PM   #3
from what i read it already has this, how do i go about adjusting it?
cheers
any more hints on things to do on my TL-01 other than throw it in the bin would be good.
Old 02-15-2005, 08:03 PM   #4
Paul_TC4's Avatar
I'm pretty sure that the TL-01 doesnt include this. I just took mine out of the dusty box and it has the plastic "non-adjustable" links. Adjusting is a bit of pain. You would have to pop it off that ball cup or whatever holds it in and screw it in or out. I would use a gauge (RPM Camber) one to make sure both sides are equall.
If you plan on keeping the TL-01 for a little longer I would get some kind of Oil Shocks first. The Friction shocks make the car very bouncy.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGL65&P=7
Next , I would definatly add ball bearings. That is another "must " for the TL-01. Duratrax sells a nice set for them.
http://www2.towerhobbies.com/cgi-bin...&I=LXTR73&P=ML
Fianlly, the car could use some lighting up. I would get:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGE91&P=7
and for some slight increase in speed:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJ63&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXEX45&P=7
hope that all helps
3D cltch adjustment miks vones2 Nitro On-Road 4 07-19-2005 01:51 PM
what adjustment? peahbeez Electric Off-Road 2 05-08-2005 04:16 PM
Timing Adjustment, What's it do? LosiFromHell986 Electric Off-Road 4 02-08-2004 04:46 PM
Steering adjustment ? DesperAuto Rookie Zone 6 07-17-2003 12:49 AM
Brake adjustment G-16 Rookie Zone 2 02-23-2003 08:16 PM
