Remove battery tray in M11
How to remove it? thanks.
Thanks but it still not able to pull out. Looks like I need to open the radio case to remove the tray but I want to confirm.
BTW, I own 3PK, EX10, they are easy to remove the tray but this M11 seems like is locked in the case.
Hate to revive a 3yr old thread, but having the same problem and can't find any info anywhere. Want to install a 3s but can't get tray out. Any help would be appreciated. Thanks.
I'm in the same boat here msave... Have you found any more info or had any luck with removing the battery tray?
It's a VERY tight fit. Just keep yanking on it, it will come out.
