Old 05-30-2012, 01:01 PM   #1
Default tc3 starting back after 10 years
hi i have dragged my tc3 out after 10years and starting back at an indoor carpet track, ive noticed everyone runs brushless now, any tips on how to still be competitive with this chassis, just until my skills return and i will upgrade chassis in the end, i currently have a 27t stock brushed motor. thanks
gracie89 is offline   Reply With Quote
Old 05-30-2012, 01:05 PM   #2
If you're planning to upgrade, save yourself the frustration and do it now.
Steve S is offline   Reply With Quote
Old 05-30-2012, 01:21 PM   #3
DARKSIDE's Avatar
What class are u running? If it's USVTA or USGT the TC 3 is perfect
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 05-30-2012, 01:43 PM   #4
Adamska27's Avatar
I still believe in shaft drive!!
Adamska27 is offline   Reply With Quote
Old 05-30-2012, 01:53 PM   #5
It brca and do u mean upgrade chassis now or upgrade electrics? I can make any style carbon for this car to upgrade it if this would make any difference, thanks
Old 05-30-2012, 11:06 PM   #6
Suspended
Lightweight electronics with brushless combo, and a battery that weighs less than 270grams will make you very competitive. Try to make 1350grams to 1400grams , and you'll be fine........
bertrandsv87 is offline   Reply With Quote
Old 05-31-2012, 02:11 AM   #7
Thank you, it's good to know i can be competitive without spending too much in 1 go, electronics will be 1st on my list. What's a good brushless combo?
Old 05-31-2012, 02:20 AM   #8
tc3team's Avatar
Spend as much time as you can getting consistant first.
A good racer can lap within 3/10ths of a second between fastest and average lap.
Then make the switch to brushless, if you are planning on racing 13.5 you will notice a difference!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 05-31-2012, 02:34 AM   #9
DARKSIDE's Avatar
what class?
Old 05-31-2012, 02:47 AM   #10
It's a brca touring car class with stock motor, they have 13.5 brushless I have 27t brushed.
Old 05-31-2012, 02:56 AM   #11
Suspended
Trust me, you don't want the aggravation of brushed motors s 17.5t brushless... I did just that this year at 360v2 race club, and burnt two 27t motors in the process without having the speed or the punch to compete. Now I switched to a novak gtb2 / ballistic 17.5t system and my average laptimes improved considerably the first day running my tc4... I run my Car at a hefty 1471+grams though, and I will recommend a lighter brushless sytem(ala tekin rs) if you want to make weight, but a light lipo battery pack is a must(ala thunderpower tp4300-2spr65d)... A low profile servo (Savox 1251) is also a must with a lightweight protoform mazdaspeed 6 body to start...
Old 05-31-2012, 03:03 AM   #12
Suspended
No way a 27t brushed catches a 13.5t brushless !!!! You will also need a front spool with losi Lcd(losa3344) drives to stop the chatter with some dremeling of the caster blocks.... Make your rear ball diff as loose as possible and good luck my friend, the new crop of drivers are very good, so practice forever....
Old 05-31-2012, 03:35 AM   #13
sosidge's Avatar
Will you give it a rest on the Losi LCD's for once!
To the OP... a simple answer...
Get your car running again, take it to the track, see how you get along.
The TC3 is still a good handling car, but parts might be harder to come by than a newer car.
27T brushed is slower than 13.5T brushless, and needs a lot more maintenance (brushes are hard to find).
Finally, don't let people tell you that you "need" this or "need" that to be competitive or to have fun. Good driving is what makes you competitive, and everyone knows how to have fun!
Old 05-31-2012, 06:43 PM   #14
Suspended
OP, be careful with those trying to regulate your posts, and let you struggle with brushed against faster 13.5t cars....I am sure they don't run their tc3/4's anymore, but want to make sure you End up last at every meet !!! You can also try the tc3 , tc4 forums for even more positive(not negative Sod...) info.....!!!!!
Old 05-31-2012, 06:55 PM   #15
Suspended
Lcd(#losa3344) drives will make your tc3 smooth like the newer kits using ecs drives and the likes.... Also efficiency will go up tremedously: almost no heat after six minute mains..... No Bearings will need replacing after years of use due to the decrease vibrations compared to cvd's....good luck...
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1755 Yesterday 11:51 AM
Electric 4wd HVAC25000 Electric Off-Road 122 06-09-2006 10:15 AM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 09:19 PM
Team Associated Nitro TC3 RTR dvargas Nitro On-Road 7 02-10-2003 08:36 AM
