Trinity duo3.5 new motor >
Old 06-02-2012, 09:23 PM
  #46
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Team Speedy
The Duo 3.5 weighs in at 175grams, however that is with the optional 12.5 high torque rotor I have in place of the stock 12.3 rotor.
RedBullFiXX is offline
Old 06-03-2012, 06:45 AM
  #47
Just received my Duo 3.5 motor yesterday and can confirm that grinding was necessary to allow timing adjustment past the 20 mark (on both sides). Very unfortunate having to do this with a brand new motor.
Unfortunately adjusting timing is still difficult as I believe the aluminum cover (with the holes for the sensor connector and 3 screws) is too tight fitting. I gave up on this and wrote to Trinity, will see what happens.
hcw5733 is offline
Old 06-03-2012, 10:28 AM
  #48
Madulla's Avatar
Nothing new. My old Duo3 I couldn't adjust the timing without taking it apart and sanding the cover till it was able to turn. Anyone else have problems with the sator tabs coming loose and shorting out? I have had 2 motors where the tabs have come apart and wiggle around till they touch and short out. They are great motors, i just had quality issues with them.
Madulla is offline
Old 06-03-2012, 04:45 PM
  #49
That is indeed an unfortunate confirmation, I'll await for Trinity's response as I think this is just too much to require the customer to grind additional material and sand the cover just to get a properly working motor. I'll hope for a good resolution otherwise this D3.5 is going to the trash.
hcw5733 is offline
Old 06-03-2012, 04:50 PM
  #50
Trader Rating: 163 (100%+)
took less then 5 minutes for me to dremel out the material that needed to be cleared to get full timing, didnt think it was that big of a deal
cjm1126 is offline
Old 06-03-2012, 06:06 PM
  #51
NolanP's Avatar
If it goes in the trash let me know I will buy it/trade for it.
NolanP is offline
Old 06-03-2012, 06:12 PM
  #52
Trader Rating: 279 (100%+)
Shouldn't have to do any grinding/sanding on a new motor after shelling out $90 or so to get it to work properly!!! Poor manufacturing and quality control I'd say!!!
Andy Koback is offline
Old 06-03-2012, 06:30 PM
  #53
I also believe that if it is teched at the nats they will look for that grinding and dq the motor. Especially with everyone talking about it.
old_dude is offline
Old 06-03-2012, 08:51 PM
  #54
NolanP's Avatar
Talked to the man today and he said the 13.5 motors are coming soon.
NolanP is offline
Old 06-04-2012, 08:55 AM
  #55
Espo's Avatar
The second batch of the 3.5's will be punched properly ....... The first batch were a total of 80.....The new batch will have a "more range to adjust"....This does not mean that max timing is the "way to go".....In testing this year on these motors one thing I found is that each motor needs to be played with in-order to find there "sweet-spot"......In other words ..I took two identical motors and found there sweet-spot and both were at a different timing mark.....
Now another point that has to be made... is that the ambient temperature outside is a major consideration to where you end up in gearing and timing....if your racing outside and start in the morning and you temp your motor and it's 190 thats great!...but in the second and third qualifier if the ambient temp goes up you have to be ready to re-adjust your timing or gear to stay at that temp....these brush-less motors are very susceptible to outside temp....so watch it....
I hope this clears things up a little......any more questions or concerns please feel free to ask here....I will try to help................................
Espo is offline
Old 06-05-2012, 07:41 AM
  #56
Espo's Avatar
All you racers that want to be faster than you are now..you must pre-order these motors now...Don't miss this batch .....They are super fast and stay kool .......get'em and gear-up!!!!
Espo is offline
Old 06-05-2012, 08:13 AM
  #57
theatriks's Avatar
When is tower gonna get these ?
theatriks is offline
Old 06-05-2012, 11:27 AM
  #58
Team EAM
Trader Rating: 79 (100%+)
The new motors are shipping now. Trinity has them on their site among others. Anyone interested can also email me for details. [email protected]
EA
EAMotorsports is offline
Old 06-05-2012, 11:38 AM
  #59
James35's Avatar
New motors as in the the new batch with the proper machining? Or are you referring to 13.5 and 10.5?
James35 is offline
Old 06-05-2012, 11:47 AM
  #60
Espo's Avatar
17.5.......13.5 to come
Espo is offline
