Old 12-17-2012, 02:57 PM   #556
shadowracer24's Avatar
I set the timing on my d3.5 to 15* and played with the gearing until I got the temps and top end speed I needed for my home track. This thing is the fastest car on the track and has reset track records twice. Believe me if you get the gearing and timing working in unison there is no need to modify the endbell at all. That will only lead to nuclear meltdown in a hurry. Have watched two go that route when they first came out. Three buy one guy all in one nights racing. Temps run 140 to 160 all night.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 12-17-2012, 03:45 PM   #557
AdrianM's Avatar
I was there...lol!. We were all turning 8.5-8.7 sec laps in 13.5 Blinky WGT. You put in the D3.5 and started turning 8.3-8.5's
BTW, I wasn't saying you need to modify the D3.5. Just noting the Revtechs allowed for more timing than the D3's.
Adrian Martinez
Old 12-18-2012, 08:30 PM   #558
SS LS1's Avatar
Trader Rating: 23 (100%+)
I'm running a D3.5 21.5 in the local USGT class and need some gearing help. Any suggestions on a recommended FDR and endbel timing setting I should try?
Thanks for your input!
SS LS1 is offline   Reply With Quote
Old 12-19-2012, 05:20 AM   #559
scootr117's Avatar
Originally Posted by Serpenteer View Post
Nice to know this information. I keep hearing about the endbell in the 3.5 needing some sort of modification?? Is this true??
Does the D3 at the 0 timing mark have any built in timing??
Sorry for the newb questions, getting back again into electric TC.
The only thing I had to do was rotate the mounting plate on the motor to move the solder tabs on my pan cars. The cooling slot eliminated one of the holes.
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 12-19-2012, 06:28 AM   #560
nexxus's Avatar
Trader Rating: 302 (100%+)
I just received mine from Express Motorsports (High Torque rotor) and noticed it came with the end bell timing set at 25 degrees.
I did a few tests on my brushless motor tester (all end bells at 0 degrees) and found that the claimed 3500kv is a load of s#it.
These tests are all at 6 Volts no load.
Duo 3.5 (Express) 13559rpm 1A draw
Turnigy Trackstar 17.5 (Silver) 13679rpm 0.7A draw
Dualsky Track and Field 17.5 14399rpm 1.6A draw
Trinity Monster Horsepower 3 17.5 14399rpm 0.6A draw
So at least on initial bench testing it has the lowest rpm of the lot and a 4 yr old Dualsky seems to have more power.
Not sure it's worth the $95 yet.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-19-2012, 06:43 AM   #561
AdrianM's Avatar
Based on the fact that the D3.5 is winning every spec motor class race in the US and everyone at my home track that has tried them have immediatly gone faster I would say your testing methods are not generating meaningful results.
Adrian Martinez
Old 12-19-2012, 09:24 AM   #562
bkspeedo's Avatar
I agree, i went .1-.2 faster than my Thunder Power and that's not even with a 12.5 torque rotor, just the standard broadband.
It would be interesting if you can test all your motors with a 20-30amp load and see which produces the highest RPM.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-19-2012, 09:45 AM   #563
Jerz616's Avatar
Trader Rating: 49 (100%+)
If your using the HT rotor your going to get less rpm anyway. Try it with the stock 12.3 broad rotor and you will have more RPM. It will likely have the same if not a little more rpm then the D3. The benefit of these motors was you could gear them taller to get more speed but not lose any low end punch. As well as running cooler. Your test isn't really equal unless all of the motors have a HT rotor.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-19-2012, 10:11 AM   #564
masterhit's Avatar
Trader Rating: 15 (100%+)
Testing without a load (and tuning) is about as effective as dropping them from the same height to decide which one is faster....
And zero is not always "zero". For some zero = 30 degrees. For others 20, etc.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 12-19-2012, 10:14 AM   #565
Jon Williams's Avatar
^This.
And John Tag from eXpress can tune a motor. Trust me.
Gear that motor properly, and it will run great for you.
Jon Williams is offline   Reply With Quote
Old 01-24-2013, 10:53 AM   #566
Dusttt's Avatar
Trader Rating: 123 (100%+)
Did Roar make these motors not legal now?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 01-24-2013, 11:18 AM   #567
klaymon's Avatar
Trader Rating: 71 (100%+)
They are illegal in the 17.5 turn only.
klaymon is offline   Reply With Quote
Old 01-24-2013, 12:46 PM   #568
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
But 90% of the tracks r still running them .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is online now   Reply With Quote
Old 01-28-2013, 02:29 PM   #569
cmy55s's Avatar
Is there any progress on these motors becoming roar legal again in 17.5? My 90 dollar paperweight would like to have its second run!
cmy55s is offline   Reply With Quote
Old 02-25-2013, 07:43 PM   #570
Dusttt's Avatar
ditto
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
