Old 11-15-2012, 04:36 PM   #481
spurcheck's Avatar
Originally Posted by Randy_Pike View Post
Some of this is true. If you have an esc that is only providing 3.5v with a properly charged receiver pack OR a properly functioning booster you have a failure in the sensor port.
It has nothing to do with the age of it.
It occurs when a voltage spike back feeds through the system, blows a component and increases the resistance of the circuit. This is where the voltage drop occurs. We only see this failure on 1s setups.
I see I am not the only racer to have experienced this anomoly. I was working with one of your team drivers in the south jersey area on the issue. Totally caught me off guard when this occured. I am meticulus about my electronics. My speedo is several seasons old. The other two RS speedos are newer. I have not tried using either of them in 1 cell configuration to see if they are prone to the same issue. What I would like to know is what is Tekin's position on this. Is there a good will exchange for those experiencing this problem? If so, can this info be found on Tekin's site and what is the racers participation if any. Just trying to determine my next course of action on this issue.
The Punter or The Punt-ee,,,,,,,,,,,,,,,,,,,who you be??
No Apologies Racing, don't believe me, try me!!!!!
spurcheck is offline   Reply With Quote
Old 11-16-2012, 11:30 AM   #482
j.d.roost's Avatar
Trader Rating: 28 (100%+)
J.J. ...I had this same issue last year with a brand new rs/pro and a s.p. motor with the high timing board (tq booster-1/12-1s setup). I had a video posted of this happening on the bench but I removed it after it was suggested by Tekin to just run a rx pack..
The booster pack resolved all issues for me.
Not sure if there is any "fix" for it if you want to run the tq booster.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 11-16-2012, 12:14 PM   #483
Trader Rating: 76 (100%+)
Originally Posted by MUDVAYNE View Post
I'm looking for a good starting point for rollout for my 13.5. The track is 80 x 42. Here is what I'm running:
WGT 13.5 blinky
13.5 D3.5
single cell
Tekin RS
80 x 42 carpet track
Any help would be greatly appreciated. Thanks!
Anyone?
MUDVAYNE is offline   Reply With Quote
Old 11-16-2012, 01:21 PM   #484
bkspeedo's Avatar
WGT 13.5 blinky
13.5 D3.5
single cell
Tekin RS
3.25" rollout, Ex. 88 spur, 44 pinion, 2.05" tire, endbell timing 25
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-16-2012, 05:03 PM   #485
Potoczak's Avatar
Trader Rating: 112 (100%+)
Hey guys what is the difference between the 12.3 and 12.5 high torque rotor for the d 3.5. What will each one do differently??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-17-2012, 07:33 AM   #486
Jerz616's Avatar
Trader Rating: 49 (100%+)
The 12.5 ht has more torque then the 12.3 ht because of the larger size. I believe the 12.3 will give you a little more torque then standard but still have a better top end then the 12.5. The 12.5 will give you the most torque but you lose the top end, but you can gear it taller to regain the top end and still have the low end rip that the HT rotor is good for.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-17-2012, 01:07 PM   #487
AdrianM's Avatar
Do the same apply for 1s racing in WGT?
Adrian Martinez
Old 11-17-2012, 04:02 PM   #488
theatriks's Avatar
Hey guys theres something wrong with my motor and im not sure what it is .....i have a 17.5 turn duo 3.5 and this motor is like the armature is wobbling and not spinning straight when lots of throttle is implemented its stripping the spurs and the mesh is correct and the spurs are straight....any ideas....Thanks.........i did unscrew both ends to slide the end plate just to get the holes to line up with the motor mount....but it when back together correctly at least it looks correct lol
theatriks is offline   Reply With Quote
Old 11-17-2012, 06:37 PM   #489
Trader Rating: 20 (100%+)
Is there any play when its put together
goots is offline   Reply With Quote
Old 11-17-2012, 07:54 PM   #490
theatriks's Avatar
A little bit pushing it in and out but that's normal and no up and down play
Old 11-17-2012, 08:11 PM   #491
Trader Rating: 217 (100%+)
Sounds like a bent shaft.
Andy Koback is offline   Reply With Quote
Old 11-17-2012, 09:47 PM   #492
theatriks's Avatar
How does that happen lol
Old 11-17-2012, 10:59 PM   #493
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
maybe something got wedged in between the pinion and spur durring a race! Dont know! You could take out the rotor and roll it on a flat surface to check!
Josh-n-ya is offline   Reply With Quote
Old 11-18-2012, 07:21 AM   #494
theatriks's Avatar
Will do...thanks!
Old 11-18-2012, 10:12 AM   #495
Taking a hard hit would do it. Should be able to take the pinion off and run the motor slow and if it's bent, you should be able to see it.
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
