Old 11-12-2012, 09:41 PM   #466
bkspeedo's Avatar
Originally Posted by Joe Kimble View Post
I'm not a specialist but I heard somewhere that braking causes a sudden increase in voltage sent back to the battery. So would imagine using a low braking profile? Just supposing really
You are correct, it's called Back EMF. But all speed controllers are designed to control this voltage spike. This would not cause the issue being discussed.
The sensor board circuit issue is purely abuse of the ESC. Make sure your ESC is properly attached to the chassis of your car and does not come loose.
Those of you that don't work in the electronic industry of no clue how much abuse above the norm RC electronics take. It's surprising they last as long as they due.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-13-2012, 09:31 AM   #467
BCbud's Avatar
Trader Rating: 37 (100%+)
Ok, I do not understand why this problem with the Tekin not working with the new D3.5 is only happening with the new D3.5 and not other motors? One racer at our track took out the D3.5 that was showing the bad sensor symptoms and put in a different motor and it worked fine. What is different in the D3.5 sensor board to cause this?
Also I replaced the sensor board in my D3.5 with an older one and it works fine. So is it the Tekin or is it the D3.5s sensor board that has changed?
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 11-13-2012, 10:30 AM   #468
Moderator
Clegg's Avatar
keep in mind there is nothing special about the sensor boards in the D3.5. They are the exact same sensor pack/PCB that the previous D3, Speed Passion, and other motors from the same mfg all use. They even have the same part number on them!
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 11-13-2012, 10:39 AM   #469
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Clegg View Post
What causes the voltage spike in most cases? Reason I ask is if everything in the car is running at ~ 4.2v (for 1S) setup, and 6v if there is a booster/pack feeing the ESC via the Rx connection. Just curious what is considered a spike and how to avoid that with my RS's ?
Most of it's from crashing and super hard board taps where the servo is under an immense load.
A receiver cap can help buffer the system but it won't prevent it outright.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-13-2012, 10:41 AM   #470
Team Tekin
Randy_Pike's Avatar
Most of the hall sensors we're all using are rated at 5v. However some work all the way down to 3v and even lower at times. So it really depends on the sensors used.
The D3.5 isn't the only motor that will do this, others do as well including our own.
Old 11-13-2012, 11:42 AM   #471
bozzplayer's Avatar
Trader Rating: 16 (100%+)
looking for a good starting point FDR, running the new D3.5 17.5 Turn MAXZILLA motor in blinky and in boosted on a 70'x50' Carpet Track
bozzplayer is offline   Reply With Quote
Old 11-13-2012, 12:28 PM   #472
I ran sunday the italian indoor championship, in 13,5 no timing category.
I use fdr 4.1 and timing 40.
In a corner exit was very good but the straight was slowly...
The temperature are 80/90 celsius...
Some advice?
marcomarino35 is offline   Reply With Quote
Old 11-13-2012, 12:48 PM   #473
locked's Avatar
Originally Posted by bozzplayer View Post
looking for a good starting point FDR, running the new D3.5 17.5 Turn MAGZILLA motor in blinky and in boosted on a 70'x50' Carpet Track
Somewhere between 3.5 and 4.0 FDR for blinky. I'd probably start around 3.8 on a track that size.
Personally, I wouldn't use one of these for boosted. Not with the 12.5 high torque rotor in it anyway. Change to an RPM rotor and start around 6.5 FDR, with plenty of boost + turbo.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-13-2012, 03:05 PM   #474
I)arkness's Avatar
ive had no problems with my tekin and d3.5 17.5 only thing i changed was im using the sensor lead from the reedy as i like how they sit flat
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 11-13-2012, 05:42 PM   #475
for 17.5 blinky i used 4.25 fdr
Shortbusallstar is offline   Reply With Quote
Old 11-13-2012, 06:37 PM   #476
Default D3.5 stock rotor?
Anybody know what rotor comes with the normal D3.5?
Also, which direction does one turn the end bell to increase timing?
Thanks!!
mhavlena is offline   Reply With Quote
Old 11-13-2012, 07:54 PM   #477
Trader Rating: 217 (100%+)
Thanks!!
Turning end bell counter clockwise increases timing. Don't know about the rotor.
Andy Koback is offline   Reply With Quote
Old 11-13-2012, 08:39 PM   #478
Jerz616's Avatar
Trader Rating: 49 (100%+)
Thanks!!
They come with the purple 12.3mm broad power rotor.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-14-2012, 12:55 AM   #479
Anyone had some advice for more straight speed in 13,5 no timing?
I use fdr 4,1 and timing 40 (80/90 celsius)
Old 11-14-2012, 05:51 AM   #480
Trader Rating: 76 (100%+)
I'm looking for a good starting point for rollout for my 13.5. The track is 80 x 42. Here is what I'm running:
WGT 13.5 blinky
13.5 D3.5
single cell
Tekin RS
80 x 42 carpet track
Any help would be greatly appreciated. Thanks!
MUDVAYNE is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
