Old 11-12-2012, 05:45 AM   #451
wollow86's Avatar
Originally Posted by cwoods34 View Post
When I ran boosted 17.5, I'd use a D3 with a 12.3 broad power rotor. The 12.5 hi-torque (Magzilla) will typically run hotter and doesn't like the high RPM of boosting... that's why it's good in blinky. The smaller/less powerful rotors run cooler and wind up faster. I'd go with the standard D3.5 from EA.... hope this helps!
Thanks for your reply, it seems hard to get info on what works with boost in 17.5, not many places left running it.
Is the 12.3 the standard rotor in the D3? I never changed mine, just ran the stock D3...
One last question, with the D3.5, would it be better to run the timing at 0 rather then the first notch in + like I did on my d3? Or possibly even retarding the timing on the end bell and adding it back in in the esc?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 11-12-2012, 06:11 AM   #452
cwoods34's Avatar
The stock rotor should be purple I believe, but I've got them with pink before. Both should work fine. I ran my D3 at the first + timing mark past "0" then boosted the crap out of it with a Tekin..... usually 6.0-7.0 FDR.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-12-2012, 09:49 AM   #453
SS LS1's Avatar
Trader Rating: 23 (100%+)
Questions??
Originally Posted by outlandr91 View Post
I could use some gearing/timing suggestions for a blinky 21.5 on a 100x36 carpet track.
Originally Posted by bvoltz View Post
Around 4.0, with a 12.3 general rotor / full timing....
So how much FDR change would you recommend with a 12.5mm HT rotor in the same 21.5 motor? Still use full timing or something less?
SS LS1 is offline   Reply With Quote
Old 11-12-2012, 10:05 AM   #454
AdrianM's Avatar
Originally Posted by I)arkness View Post
was using the 17.5 yesterday and went to put on full timing on the end bell and it didn't quite get there, stopped i think at around 20 degrees? any info on this or should i pull the thing apart and see why.....
0 timing is 30 deg on the D3.5. If you were running 20 degrees on the endbell you were at the max 50 deg of timing.
Adrian Martinez
Old 11-12-2012, 03:47 PM   #455
I)arkness's Avatar
oh really didnt know that, thanks for the info
but why do they bother having it go up to 30 on the endbell markings?
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 11-12-2012, 04:17 PM   #456
NolanP's Avatar
Probably for the same reason your speedo goes to 160-200mph.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 11-12-2012, 04:20 PM   #457
I)arkness's Avatar
ah touché
B.Portelli
Old 11-12-2012, 05:56 PM   #458
bvoltz's Avatar
Trader Rating: 44 (100%+)
Because it was a design issue with the pad printing on the end bell....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 11-12-2012, 05:56 PM   #459
AdrianM's Avatar
I'm not sure. Maybe its brilliant marketing on Trinity's part. Every few weeks someone asks this and the D3.5 thread springs back to like...lol!
Adrian Martinez
Old 11-12-2012, 06:18 PM   #460
Originally Posted by syndr0me View Post
We found out at IIC that earlier versions of the Tekin ESC have issues with the voltage being used in the sensor board of the d3.5. Contact Tekin and see what they can do for you. I believe they were replacing ESC's for people at the race that had the older version.
When one refers to "older" tekins, does one refer to older firmware than v2.23?
Are you saying that ones needs to have the Gen 2 Tekin to work with a D3.5?
Thanks!
mhavlena is offline   Reply With Quote
Old 11-12-2012, 06:27 PM   #461
Trader Rating: 217 (100%+)
Thanks!
I've also heard that replacing the sensor board on the D3.5 with one from a D3 will work with the older Tekins too. Worth a try if you have one on hand.
Andy Koback is offline   Reply With Quote
Old 11-12-2012, 06:36 PM   #462
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Some of this is true. If you have an esc that is only providing 3.5v with a properly charged receiver pack OR a properly functioning booster you have a failure in the sensor port.
It has nothing to do with the age of it.
It occurs when a voltage spike back feeds through the system, blows a component and increases the resistance of the circuit. This is where the voltage drop occurs. We only see this failure on 1s setups.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-12-2012, 06:39 PM   #463
Moderator
Clegg's Avatar
What causes the voltage spike in most cases? Reason I ask is if everything in the car is running at ~ 4.2v (for 1S) setup, and 6v if there is a booster/pack feeing the ESC via the Rx connection. Just curious what is considered a spike and how to avoid that with my RS's ?
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 11-12-2012, 08:57 PM   #464
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Is there a particular pin out we can check the voltage at on the sensor portion of the esc to see if we are getting proper voltage?
Old 11-12-2012, 09:02 PM   #465
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
I'm not a specialist but I heard somewhere that braking causes a sudden increase in voltage sent back to the battery. So would imagine using a low braking profile? Just supposing really
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
