Trinity duo3.5 new motor >
Old 05-31-2012, 09:49 AM
  #31
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by NolanP
Come race at leisure hours where the straight is 225 feet
I'm sure it's a whole different game.
Interestingly, at Reedy, there were almost no Trinity motors in the top 10 of any class.
http://rcprogear.com/tagged/reedy12
syndr0me is offline
Old 05-31-2012, 10:08 AM
  #32
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by syndr0me
Like torque? For indoor carpet racing, I'm starting to find torque more beneficial than RPM.
I would guess at torque....but until I actually get some to test and see I dont know for sure. Im not educated enough in the design aspect to know for sure but logically if you take Iron away it takes away part of the magnetic field it would seem. Its a better question for Dieter, Howart, Cochran or someone of their design knowledge.
EA
EAMotorsports is offline
Old 05-31-2012, 10:59 AM
  #33
Trader Rating: 3 (80%+)
I don't think thats a reflection on the performance of the Trinity motors, more of a regional preference.
Josh Hohnstein is offline
Old 05-31-2012, 12:56 PM
  #34
Yeah, they won't go above 25 degrees. But fast at that setting ran mine last night.
gerryriccio is offline
Old 05-31-2012, 10:19 PM
  #35
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Doesn't take much to fix the timing adjustment...
I always pull my motors apart and make sure the rotor is spaced correclty. It only took about 10 min with the dremel to fix the timing ring... No big deal and now I can turn it up to 40+ if needed...
JFuel11 is offline
Old 06-01-2012, 05:44 AM
  #36
NolanP's Avatar
How do you feel the band is on the motor? Does it pop out of a corner really hard yet feel like in a drag race it could be lacking? Or vice versa? Or what?
NolanP is offline
  #37
NolanP's Avatar
NolanP is offline
Old 06-01-2012, 01:47 PM
  #38
kp-61's Avatar
Here is a video on tear down on a 17.5
http://www.youtube.com/watch?v=IneB3e6X5BI
one regarding the end bell.. still have to do the dremel trick.
http://www.youtube.com/watch?v=xp9cycigHTI
I am really happy about the motor I can now figure out how many degrees I adjust the timing...
Sorry did not have time to edit.
kp-61 is offline
Old 06-01-2012, 04:54 PM
  #39
RCMICK's Avatar
Anyone know where you can find one?
RCMICK is offline
Old 06-01-2012, 05:21 PM
  #40
jsr555's Avatar
Trader Rating: 18 (100%+)
Is this just the next generation Duo motor, or do you think this (the DUO 3.5) has been specifically designed to maximise performance in 17.5 Blinky class?
jsr555 is offline
Old 06-01-2012, 05:57 PM
  #41
TeamWTF's Avatar
It sure is heavy! Thats about the weight of the regular duo3 is I'm not mistaken. I thought it was supposed to be lighter?
TeamWTF is offline
Old 06-01-2012, 07:54 PM
  #42
NR
NR's Avatar
Trader Rating: 52 (100%+)
I believe the end plate is lighter as well as the rotor not the whole motor as such
NR is offline
Old 06-02-2012, 09:49 AM
  #43
NolanP's Avatar
Great videos but has anyone told you that you talk too much in them?
So I'm assuming you can just Dremel that end plate and be able to go as high as you want?
NolanP is offline
Old 06-02-2012, 10:38 AM
  #44
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
What does the D3.5 17.5 weigh in at ?
RT 17.5 with CEFX endbell = 160.7gr
MurDogg 17.5 = 155.8gr
LRP X12 17.5 = 167.4gr
RedBullFiXX is offline
Old 06-02-2012, 06:44 PM
  #45
Team Speedy's Avatar
Trader Rating: 55 (100%+)
Exclamation
Originally Posted by RedBullFiXX
What does the D3.5 17.5 weigh in at?
The Duo 3.5 weighs in at 175grams, however that is with the optional 12.5 high torque rotor I have in place of the stock 12.3 rotor.
Team Speedy is offline
