Old 10-04-2012, 10:14 PM   #421
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Got my 17.5 today. I soldered it in and went to adjust the timming and loosend the three screws and it wouldnt turn any direction. I loosened it up almost where the screws were coming out and timming still wouldnt move. Took the motor out of the car loosened the three main screws holding motor together and timing finally moved. WTH Something is wrong with this picture. When the motor screws are fully tightened the timming endbell cannot move even with screws out. Can anyone tell me whats wrong! thx
Josh-n-ya is offline   Reply With Quote
Old 10-05-2012, 01:16 AM   #422
Suspended
Thumbs up
Nothing is wrong with your motor, and that's the way to change the motor timing in most other brands too: Novak, etc..... You don't have to overtighten the sensor board screws anymore to keep it from moving . You do have to check your rotor shimming though after retightening your main screws.
bertrandsv87 is offline   Reply With Quote
Old 10-05-2012, 09:52 AM   #423
Josh-n-ya's Avatar
Just read three or four pages of this thread and found out whats going on. How would I know what batch of motors I got. Will have to break out the drimel cause yes my timing only goes up to 20ish too. New motor!
Old 10-05-2012, 09:59 AM   #424
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
20 degree mark the most you are suppose to go to . The motor has 30 degrees at the "0" mark . This was mentioned several times a few pages later on .
There was a lot of confusion about this when the motors first came out and when this thread started .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-05-2012, 10:01 AM   #425
Jerz616's Avatar
Trader Rating: 49 (100%+)
The timing is only supposed to go to 25. There is already 30* built in. So you don't want to run more then 25 on the endbell. No dremel needed.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 10-05-2012, 12:07 PM   #426
redbarton's Avatar
So, I'm interested in a D3.5 21.5 turn motor. We run a variant on the VTA class with 21.5 motors locally. We are just about to start carpet season. The back stretch is about 70-75 long. Would I be happy with a D3.5? Is all that extra kv (and RPM?) going to be useful to me? Or, should I just stick with a Revtech 21.5, which has less kv? Thoughts?
redbarton is offline   Reply With Quote
Old 10-05-2012, 12:52 PM   #427
Jerz616's Avatar
I would definitely get it. You can gear it really tall if needed and still have a ton of rip on the infield. You could prob add 2 teeth to your pinion and still have better rip then the revtech and be able to have more top end.
Ryan Gracey
XRAY XB8'14
Old 10-05-2012, 02:22 PM   #428
Josh-n-ya's Avatar
Got it figured out! I did have to dremel a little bit inside the the housing where the sensor board moves from side to side. Some solder tabs were rubbing not allowing the sensor board to move smoothly.
Old 10-28-2012, 05:19 PM   #429
Trader Rating: 17 (100%+)
Anyone have a good starting point for the D3.5 21.5 in USGT on a 90 x 48 track that flows?
429racer is offline   Reply With Quote
Old 10-28-2012, 05:46 PM   #430
B00t13g's Avatar
Originally Posted by 303slowdown View Post
Maybe I'm missing something, I got one of these motors in a 13.5 for 1/12 and am not impressed . I see no difference between it and my thunder power, it feels the same , runs the same lap times and comes off at the same temps. Are other really seeing such gains or is it just new motor dillusions.
There's no denying the d3.5 is a good motor, I really like it in my buggy and 2wd sct, but I did not love it in my sedan. I much prefer a reedy or a schurr speed. The thubderpower with the right rotor is great as well.
Try a schurr speed 13.5. I love mine. Super smooth with great power everywhere. I'm at a 4.3fdr and 40 degrees of timing and its killer.
B00t13g is offline   Reply With Quote
Old 11-04-2012, 11:30 AM   #431
What is the best choose between the standard version and Maxzilla for blinky 13.5t on road racing ?
Thanks a lot
shiver750 is offline   Reply With Quote
Old 11-05-2012, 03:12 PM   #432
theatriks's Avatar
Hey guys running 17.5 boosted on a 70x50 carpet track ...can this motor handle a 3.7 fdr in boosted or should I start around 4...thanks
theatriks is offline   Reply With Quote
Old 11-05-2012, 03:52 PM   #433
artwork's Avatar
Trader Rating: 62 (100%+)
I think 3.7 could be a bit high for a track that size...I would start closer to 4 and work down as the motor can handle it.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-05-2012, 04:18 PM   #434
syndr0me's Avatar
Trader Rating: 32 (100%+)
For boosted I think you'd want to be like 5.5 or 6. It's been a while, but I'd think 3.7-4 would be blinky range.
syndr0me is offline   Reply With Quote
Old 11-05-2012, 04:20 PM   #435
NolanP's Avatar
Yeah I would personally be around the 4 range to start in blinky.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
