Old 09-11-2012, 02:17 AM   #331
Default Roll out for Duo3.5 4.5T 5.0T
Hi,
Any estimate for which roll out I should use for Duo3.5 4.0T, 4.5T and 5.0T ?
This is for 1/12 pan car.
ongbenghui is offline   Reply With Quote
Old 09-11-2012, 05:48 AM   #332
Trader Rating: 1 (67%+)
Originally Posted by ongbenghui View Post
Hi,
Just wondering if anyone got problem with the mounting holes on 1/12.
The mounting holes is such that if I use a top & bottom holes layout, the motor connector will be angle 30~40 degree. If I want the motor connector to be on top, I will need to use the 2 lower holes together. But is the motor mount "stable" enough to use the 2 lower holes ?
If you remove the 3 screws on that end of the motor that end plate can be rotated so it should work the way you want it to.
Josh Hohnstein is offline   Reply With Quote
Old 09-11-2012, 07:05 AM   #333
NateRug's Avatar
Originally Posted by to slow for you View Post
i got a 17.5 its gutless might be good for 1/12 not for touring class may be its just my luck
Did you gear up at all from where you were geared before?
MMR Spec VTA - 17.5 Brushless, 1c Lipo
21.5 Pro-lite 1/12th scale - CRC Xi
17.5 Rubber Sedan - Xray T3 2012
Offroad : Xray XB4 - Tekin Redline 8.5 Gen2 - Tekin RS Pro
NateRug is offline   Reply With Quote
Old 09-11-2012, 07:18 AM   #334
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Hi,
You can remove the three screws and rotate the endplate so the holes match up .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 09-11-2012, 08:15 AM   #335
NolanP's Avatar
A few of us are running the D3.5 in 12th scale and its going well. Its pretty darn fast and I'm sure as I only have a few runs on it that there is more to be desired but its plenty quick with the right gearing.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 09-11-2012, 08:27 AM   #336
Hi, what is the rollout that you uses ? and how many T in your D3.5 ?
Just want to get an idea.
Old 09-11-2012, 09:15 AM   #337
NolanP's Avatar
Still testing rollout. I am running max timing currently..still havent tried dropping it. Just getting used to this carpet thing here.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 09-11-2012, 09:57 AM   #338
spammy's Avatar
So what are people running for FDR in 17.5 on carpet in tc track size about 100 x 60 just want to see where you folks are at
spammy is offline   Reply With Quote
Old 09-11-2012, 10:37 AM   #339
NolanP's Avatar
3.8-4.3 pending timing and track layout.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 09-15-2012, 08:26 PM   #340
earlier this eek i ordered the ht rotot for my 3.5. the track i run on is outdoor asphalt. there is a 45 degree corner leading in to the 120 foot straight that ends with a sweeper , there are also a couple of 180's. In trying to be competitive with the other cars on the track i kept chasing my gearing and settled with a 80 /47 with an internal of 2.0 leaves me running a 3.404. finally settled on timing of 20 degrees on the endbell and the car was pleasantly fast,at least for 5 minutes. 14.0 - 14.5 laps. then at the last minute motor gets real flat and i run at 14.6- 15.1. temps inside the endbell vents were in the low 140's.
so i backed the timing off 4 degrees and lap times became atrocious through out the run...low 15's were my best times.similiar results with 2 battery packs.
pack a is a revtech 65x65 about 6 mos old, pack b is a reedy 65x65 with today being raceday 4 on the pack.
temps with the lower timing were still at 140 and i am running a geiss fan.
can anyone tell me why i am getting so much fade ???
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 09-15-2012, 08:31 PM   #341
NolanP's Avatar
Sounds like you are really using a super small spur...
Give me more specifics....What car are you running? Have you tried max timing?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 09-15-2012, 08:34 PM   #342
Jerz616's Avatar
Trader Rating: 49 (100%+)
Wow. Thats all I can say. I have been putting off getting a 3.5 because I didn't think it could be that much better. I have ran 2 other great motors and lived them. But I bought a 3.5 today cuz I wanted a good back up for the southern bats coming up. And holy crap. This thing flys.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-15-2012, 08:43 PM   #343
car is a photon ex,tried max timing(23degrees) but didn't see much difference between 20 and 23... and i am running a small spur,80 tooth
Old 09-15-2012, 08:43 PM   #344
NolanP's Avatar
Yes it is. The crazy part are the tolerances of the rotors and stators aren't very far apart. So what you pull off a shelf can be just as fast as the one the "pro"s pull out of a box.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 09-15-2012, 08:50 PM   #345
Trader Rating: 217 (100%+)
If you truly believe that, I got some Lake Front in Arizona that I'd like to sell you!!!
Andy Koback is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
