Old 09-03-2012, 10:08 PM   #316
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by gwhiz View Post
Is that TEP1112?
For your 1/12..... sweet!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 09-04-2012, 09:01 AM   #317
Default 4.5T or 5.0T for 1/12 ?
Hi,
I am thinking of getting the 4.5T or 5.0T for 1/12.
But I noticed that the Kv rating is much higher compared to others.
For instance, the Duo3.5 5.0T is rated for 9000Kv and 4.5T is rated for 9300Kv. Is that real ?
Compared to Nosram Pure 2, or LRP X20, 5.0T is only 6900Kv and 4.5T is 7600Kv.
How should I gear it for 1/12 then ? which rollout should I use ?
Any advise ?
ongbenghui is offline   Reply With Quote
Old 09-04-2012, 09:14 AM   #318
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by ongbenghui View Post
Hi,
Any advise ?
Companies measure KV in different ways which makes comparing them nearly impossible. If you go with the D3.5 just start with the gearing a little milder than you normally would for each wind and go from there. I dont think enough people have ran them in 12th modified to give you a good answer yet.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-04-2012, 09:20 AM   #319
seth556's Avatar
Trader Rating: 42 (100%+)
Kv also varies with timing, so going from a few degrees or timing to maxing out your timing will greatly vary a Kv rating. That's why Kv ratings are silly with sensored motors.
seth556 is offline   Reply With Quote
Old 09-04-2012, 11:33 AM   #320
B00t13g's Avatar
Originally Posted by Warren Weaver View Post
I worked countless hours with different rotors the ht 12.5 is best for all tracks tons of rip and top speed
Does that hold true for tc as well?
B00t13g is offline   Reply With Quote
Old 09-04-2012, 04:23 PM   #321
Default 3.5
i got a 17.5 its gutless might be good for 1/12 not for touring class may be its just my luck
to slow for you is offline   Reply With Quote
Old 09-04-2012, 05:13 PM   #322
NolanP's Avatar
I'm running the same D3.5 that I ran in my 13.5 TC as I am in my 12th scale. Its good so far.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 09-06-2012, 04:19 PM   #323
Trader Rating: 163 (100%+)
Default 13.5 fdr
anyone have a good starting point for fdr in 13.5 blinky tc with this motor?
cjm1126 is offline   Reply With Quote
Old 09-06-2012, 05:51 PM   #324
NolanP's Avatar
Big open track 4.2 range. Small track some where close to 5 I would imagine.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 09-06-2012, 06:32 PM   #325
Hi,
Anyone know what is the size of bearing used in Duo3.5 ?
Old 09-06-2012, 06:36 PM   #326
bvoltz's Avatar
Trader Rating: 44 (100%+)
Hi,
1/8 x 3/8 x 5/32
Here a link to the bearing... Link
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 09-06-2012, 07:52 PM   #327
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
4.0 with the 12.5 ht rotor
Warren Weaver is offline   Reply With Quote
Old 09-06-2012, 09:44 PM   #328
Trader Rating: 20 (100%+)
also 20 timing w/ fan
goots is offline   Reply With Quote
Old 09-06-2012, 10:19 PM   #329
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Check your ESC these motors are fast in my TC and other cars in my area. I had to change my setup to get more steering!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 09-11-2012, 02:16 AM   #330
Default mounting holes
Hi,
Just wondering if anyone got problem with the mounting holes on 1/12.
The mounting holes is such that if I use a top & bottom holes layout, the motor connector will be angle 30~40 degree. If I want the motor connector to be on top, I will need to use the 2 lower holes together. But is the motor mount "stable" enough to use the 2 lower holes ?
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
BEST 17.5 MOTOR FOR STOCK RACING tibbs Electric Off-Road 22 07-14-2012 01:20 AM
17.5t looking for new motor Craig W Electric On-Road 8 07-28-2011 05:37 AM
