Old 02-14-2005, 11:04 PM   #1
f2000racer's Avatar
Default Traction Roll problem
Can anybody help me with this problem.
I'm running on Ozite carpet only about 2 to 3 months old. What I notice is that after 3 5min heats, my car would start to traction roll entering a corner.
Anybody has this problem and what setup should I have to fix this problem.
I'm using green springs on the front and orange on the rear; double pink orange front foams and double purple for the rears.
Thanks in advance.
Roy
f2000racer is offline   Reply With Quote
Old 02-14-2005, 11:14 PM   #2
Pro4's Avatar
Try shortening your front camber link. I had this problem and the front link fixed it.
Pro4 is offline   Reply With Quote
Old 02-14-2005, 11:44 PM   #3
f2000racer's Avatar
By shortening the front camber link, will increase the negative camber right??? This car is new to me so I'll have to look at it and see if I'm wrong.
Thanks.
Old 02-14-2005, 11:49 PM   #4
f2000racer's Avatar
Sorry I was suppose to post this in the Yokomo MRTC SD thread.
Old 02-15-2005, 03:17 AM   #5
Pro4's Avatar
It wil affect camber considerably but just adjust it to how you had it. The change will still have full affect if your camber is the same as it was.
Old 02-15-2005, 04:50 AM   #6
sosidge's Avatar
You should set the camber so the tyre wears evenly If you need anything more than 2 degrees to get even tyre wear, I would say your front springs are too soft.
Traction rolling is normally because you are too soft (i.e the car rolls too much as it transfers weight, and tips), sometimes if you are way too stiff it will happen too (ie too stiff to ride the bumps in the carpet, flipping the car over).
I can't think of an orange Yokomo spring off the top of my head - what are the part numbers?
Old 02-15-2005, 05:20 AM   #7
BuddyB's Avatar
Send a message via AIM to BuddyB
If it is really high bite, then try supergluing the sidewalls of your tires. That was my problem when i was rolling.
-Buddy
BuddyB is offline   Reply With Quote
Old 02-15-2005, 05:34 AM   #8
ringo's Avatar
shortening yr top camberlink will increase the rate of camber change as the suspension compresses.
try raising your roll centre. check out the team orion website for an excellent explanation of how roll centres work.
Jarrod Currie
ringo is offline   Reply With Quote
Old 02-15-2005, 11:34 PM   #9
Pro4's Avatar
I'm speaking from experience. I had a seveer traction roll problem about a month ago and the front camber link fixed it. It DOES work
Traction Roll ? gansei Nitro On-Road 75 10-12-2012 12:38 AM
traction roll dor dummies eduardo_garcia Nitro On-Road 5 10-21-2007 10:55 AM
Traction Roll penmark67 Electric On-Road 9 06-27-2007 02:53 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 05:12 PM
Traction/wheelspin Problem????? Steevo Electric On-Road 11 12-08-2002 02:52 AM
