TC4 Build Problem
TC4 Build Problem
Hi All,
I just finished building my New TC4 car. I went out and bought all the electrics for the car.
I went with a Cobalt 7t Motor, LRP A.I. Automatic Bullet Reverse, HiTec 645MG Servo, and HiTec Aggressor 2ch. AM.
Here is my problem, after installing the servo and the motor, I have no room for both the ESC and the receiver to lay flat on the chassis. So what are my options? I am guessing that the ESC need to be mounted to the chassis? Can I mount the receiver on its side or on top of the servo? Will this cause problems? I know I need the receiver to be at least 1 1/2" away from the power lines.
What should I do?
Thanks for your time.
Nick
What should I do?
Nick
at worst you can mount your reciever on top of the servo. only bad thing is that you're stacking weight.
Originally posted by RC Driver Gary
I ran my TC4 in the Brushless class @ the Novak race and also had to mount my receiver on top of my servo. Works nicely and only slightly raises CG.
I seriously doubt even Masami Hirosaka himself could "feel" the difference between an Rx mounted on top of the servo and behind it.
Are there any negatives about mounting the receiver vertically?
u can barely tell the difference or none at all. some pro drivers mount their synthesized rc vertically.
never had a problem mounting mine vertical. as it is now.
This is what i was thinking of doing?
What do you guys think?
Thanks,
Thanks,
sure why not.,
oh but ditch the tamiya plugs.
And solder the wires direct? And are you talking about the battery and motor plugs?
since its that close if you dont switch your motor out too often id solder the motor and esc. for the battery-esc id use deans if you dont want the trouble of hardwiring. tamiya ones WILL melt on you.
