Old 02-15-2005, 04:25 PM   #16
Originally posted by TC3
i second that !
i also tried the yellow ones with cs27 tires, in cold condition, works very well !!
At Tower i found that yellow and blue are discontinued. Only black!
Where can i find them?
Capone_GR is offline   Reply With Quote
Old 02-15-2005, 04:52 PM   #17
iamramos's Avatar
last year sorex b firm in hot weather and b medium in colder temps in extreme temps Xenons seem to hold up better but both worked about the same for me. I also ran at a venue that ran gas, when the oil came up the sorex's ran fine all day regardless of the heat.
iamramos is offline   Reply With Quote
Old 02-15-2005, 05:02 PM   #18
iamramos's Avatar
last year sorex b firm in hot weather and b medium in colder temps in extreme temps Xenons seem to hold up better but both worked about the same for me. I also ran at a venue that gas, when the oil came up the sorex's ran fine all day regardless of the heat.
Old 02-15-2005, 06:08 PM   #19
Also,
do you glue your inserts on the rims?
Old 02-16-2005, 01:12 AM   #20
Eirik's Avatar
Capone,
The Orion and JB/Orion are different, you want the the Asphalt inserts Part#71002 Blue/Medium!!
Don't glue the inserts to the rim, just leave them free in there....
Eirik is offline   Reply With Quote
Old 02-16-2005, 06:25 AM   #21
I would like to try Orion inserts.
Omnimodels and Tower discontinued!
Where can i find?
Old 02-16-2005, 07:33 AM   #22
Eirik's Avatar
Have you tried the Orion Dealer in Greece??
RC Hobby Athens
Old 02-16-2005, 08:28 AM   #23
hierog's Avatar
I usually run Sorex 36R's with Xenon gray's when the temp's are hot.
I'm a fairweather racer!!
hierog is offline   Reply With Quote
Carb Inserts ???? rltanner Nitro Off-Road 11 10-24-2007 10:52 PM
re using inserts? aus jd 2703 Electric On-Road 4 07-25-2007 10:36 PM
what inserts?? odawg315 Electric On-Road 1 10-25-2005 02:43 PM
Inserts Hugo Electric On-Road 0 06-02-2003 02:31 PM
inserts TRL Electric On-Road 4 11-26-2002 02:36 AM
