Tekin RS Pro on 1s
hi all
Im asking this on behalf of a friend, is there a way to run this esc on 1s, he said there was an option on the Hotwire to set it up for 1s but it does work for some reason, does it need a certain firmware to run properly??? Regards AJ |
Is he using a receiver pack or voltage booster, as is required?
dont think so, but that makes complete sense, ill pass on your info and thanks for your prompt reply
Tell him to run a 2s LiFe pack plugged into the batt port on the receiver, leave the red wire in the RSPro receiver plug and it should work normally.
Originally Posted by TY@TEAMTEKIN
(Post 10760200)
Originally Posted by Andy Koback
(Post 10760434)
Remember to use the Off/On switch on the reciever pack, not on the ESC.
