Old 02-12-2005, 03:49 PM   #1
imjonah's Avatar
Default BEC voltage, servo speed, FET and digital servos
1. Virtually every under $100 ESC lists BEC voltage as 5 volts
while only the top of the line ESCs list 6 volts
most servos list 4.8v speed and torque and 6v specs are faster and higher torque. Does this mean that when I use a less expensive ESC with 5v BEC rating my servo will be slower and have less torque? Is their any remedy for this besides a more expensive ESC or the weight of a battery pack?
2. Digital servos draw more current. I guess some ESC and receivers have a FET output wire. Is this something that helps or will the digital servo still plug into the standard receiver?
imjonah is offline   Reply With Quote
Old 02-13-2005, 10:45 AM   #2
imjonah's Avatar
Default I am assuming the answer is ?
I am assuming the answer is ....Yes, you need to buy a 100+ pro-ESC if you want 6 volts sent to the servo so you can get its best speed and torque.
Old 02-13-2005, 11:27 AM   #3
Neil's Avatar
Send a message via MSN to Neil
Yes you want the esc with 6 volt bec. The novak GT7 and GTX both have 6 volt output. If you are running a cheap esc you will notice much better throttle control with a better esc also.
Neil is offline   Reply With Quote
Old 02-13-2005, 01:27 PM   #4
fatdoggy's Avatar
R/C Tech Charter Subscriber
A good esc will last a long time if taken care of. I spent $140 on a keyence 3+ years ago and it still works like the day I bought it. You could use a reciever pack to drop 6v into the servo but imo they are a pain in the butt.
fatdoggy is offline   Reply With Quote
Old 02-13-2005, 02:56 PM   #5
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
What the heck is a 'coreless' servo?
-JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-13-2005, 04:39 PM   #6
Cole Trickle's Avatar
-JB
Coreless is a certain type of electric motor. One of their advantages is more smooth... maybe other advantages, cant remember
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-13-2005, 04:43 PM   #7
Default Re: BEC voltage, servo speed, FET and digital servos
There's no relation between the current draw of a digital servo and the socalled FET wire.
Each and every digital servo draws more current, regardless of they have a FET wire.
Servos with a FET wire, do get 7,2 volt directly from the main battery. Thus they get a higher voltage (=more speed) AND there's no current limiter in the BEC in the ESC.
So if you already have a speedo, which you're happy for, the remedy could be to get a servo with a FET wire However, we're talking 100$-servos. But again, a fast servo is a grate, yet overlooked, hop-op, which will last for years and can be taken to the next car
Old 02-13-2005, 04:46 PM   #8
That extra battery pack means quite a lot extra weight....
Check out this speedo - it's a Duratrax, but it's actually a rebadge Novak
Or check out the Novak Dually, nice speedo with 6 volt BEC and other nice stuff... Dont know the price though, but it might fit your budget...
Old 02-13-2005, 05:14 PM   #9
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
It's mainly an issue with BEC current, not voltage....
Most basic ESC's BEC only put out about 1A...
When the servo tries to draw more than 1A, the voltage drops...
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 02-13-2005, 05:26 PM   #10
Hmmm. Dropping from 6 to 5 volt, means a speed loss of approx. 25%... At my opinion, that's quite a lot. But I highly agree about the current, that'll make it even worse
Old 02-13-2005, 05:27 PM   #11
If interested, here's an interesting document about digital servos here.
Old 02-13-2005, 08:40 PM   #12
DrOlds's Avatar
FWIW all my "obsolete" Tekin escs have 6v 5a bec.Also, I read on Kinwald's thread on the Trinity site that he doesn't use digital servos-doesn't like them.
DrOlds is offline   Reply With Quote
digital high speed servo Racers Concept Australia Wanted to Buy 1 10-22-2007 01:11 AM
Need high speed digital servo LosiSuperTruck R/C Items: Wanted to Buy 6 12-09-2005 08:58 AM
WTB High Speed Digital Servo yahhoo R/C Items: Wanted to Buy 3 04-14-2005 07:19 PM
Brand New Futaba Digital Servos and HRS High Speed FM Receiver For Sale racer rich R/C Items: For Sale/Trade 10 02-22-2005 10:48 AM
FS: Futaba Digital 9451 High Speed/Torque Servos e420x R/C Items: For Sale/Trade 8 09-09-2004 01:21 AM
