Batteries for Mod
Hey Guys
I dont know if this has been asked before but could anyone recommend what brand and voltage/runtime batteries i would need to run in mod? The motor will be a brushless system Any advise or suggestions would be great Thanks :) |
Anything in the 1.18+ range of voltage and over 400sec of runtime on a 30amp discharge.
Or 1.17+ and 370sec on a 35amp discharge. and always a low IR. I use Orion and Promatch but other great matchers are SMC. Fusions I still use one of theres. Yokomo if you can find them. Keep this in mind when buying matched cells 1) Is the company a name that has been around for years? 2) Are the prices reasonable? 3) What are the guys who are winning with running. I like what I like but if you ask such a general questions you are going to get a large pool of opinions. Go to the websites of major matchers and read up. Hope this helps. Stephen <>< |
Fusion batteries are great. Their team and factory team packs would be great for mod.
You don't need 1.18+ voltages to run mod. I have a few 1.18 packs, but most of them are 1.175-1.179 and the difference isn't noticeable. If you have the opportunity to hand select packs from a hobby store or somewhere else, if you are running mod the best things to look at are run time and IR. Josh |
Visit Team High Velocity they're a newer company, but offer the same if not better batteries & motors as some of the older/more expensive companies.
[QUOTE]Originally posted by Mr. Shookie
[B]Anything in the 1.18+ range of voltage and over 400sec of runtime on a 30amp discharge. Or 1.17+ and 370sec on a 35amp discharge. and always a low IR. YOU DO NOT NEED 1.18 CELLS ! LEARN TO DRIVE AND SET UP YOUR CAR THEN WHEN YOU MAKE THE A AT THE NATS SOME ONE WILL GIVE YOU A 1.18 PACK!!!!!! |
Thanks for your replies
Would these batteries be any good for mod? As for learn how to drive i can drive and make the A in nitro so i can handle mod. http://www.speedtechrc.com/store/ebp...nid=133&id=698 Thanks Guys |
Originally posted by TRAJ As for learn how to drive i can drive and make the A in nitro so i can handle mod. http://www.speedtechrc.com/store/ebp...nid=133&id=698 Thanks Guys yes you did hahaha you will proberly get A-main when no one is racing :smile: :lol: :tire: regards John .M |
I can 9th cause my front belt snapped
causing it to be 2wd against 4wd and if you do your math you would know that wont win you a race dickflop! stop filling up my threads with your garbage (stasi) |
Who is (Stasi) and dont start calling me a dickflop im going to report you to the Regional Moderator
Regards John .M |
do it get off my threads :rolleyes:
i will and i can look and reply to what ever topic i want thankyou READ THE CONTRACT
i didnt say you cant reply to any topic but what you have replied has got nothing to do with this topic
unless you got some battery advice then dont reply! |
run a 1400mah tamiya racing battery there GREAT but charge it at 7 amps:eek:
Originally posted by Xu1-235 run a 1400mah tamiya racing battery there GREAT but charge it at 7 amps:eek: |
