Old 02-12-2005, 11:22 PM   #16
Integrated's Avatar
Send a message via MSN to Integrated
I should get my I-Power 12volt 20amp power supply soon, will post pics when i have finished building the clear perspex box and done all the wiring etc, its a pretty gutsy power supply because its a 2 channel one, my CDC's i am getting each take a max of 7amp but i might end up only charging at 5amp (7amp would kill my new 3300's real quick)
it would be pretty cool to fit a neon in the box but maybe thats going overboard !
Integrated is offline   Reply With Quote
Old 02-12-2005, 11:28 PM   #17
Trader Rating: 28 (100%+)
Here's the one I'm using now. I put bolts thru the back of the power supply case to just plug on to. Only used the 12 volt power as my charger will run a lathe and do break in. When running the bolts thru, I drilled a hole twice the size of the bolt so the bolts wouldn't contact the metal, and used plastic washers to insulate.
jbrow1 is offline   Reply With Quote
Old 02-12-2005, 11:46 PM   #18
Im using a Much-More power supply and it works very well, no problems at all.
Steve
Flash-R.C. is offline   Reply With Quote
Old 02-13-2005, 10:30 AM   #19
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default 12v 7a power supply
12v 7a power supply -will this work for a competition electronics turbocharger? only going to run that charger to this power supply nothin else? is the power supply pulling enough amp or whats a good voltage and ampage for a power supply? ny help well appreciated
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-13-2005, 12:28 PM   #20
It will probably work for the time being. Don't know how good it would be running the charger with that low of amperage. 10 amps or more would be much better. 12 to 15 volts is recommended for most chargers I believe. But they will run on as little as 10, and run great on 12. But with only 12 volts, you won't be able to charge things like your transmitter battery or say a starter box gel cell. But I don't know anything about your charger, maybe it wouldn't do those anyway.
Old 02-13-2005, 05:09 PM   #21
Integrated's Avatar
How many amps does your charger charge at crACkeD ChaSsiS ? as long as you cover the amount of amps you charge with you should have no problems.
Old 02-13-2005, 05:13 PM   #22
Yes, but say you charge at 6 amps, then you're only leaving your charger 1 amp to run itself. I don't know how many it takes... but that's besides the point. Running electrical appliances (charger, dishwasher, whatever) with low amps is what burns them up.
Old 02-13-2005, 05:16 PM   #23
Integrated's Avatar
thats true jbrow1, i also heard that if you have to many amps it can also cause damage but why would people say that when car batterys have a massive amount of amps and never blow up our chargers ? doesnt make sense.
I would have thought the more amps the better !
Old 02-13-2005, 05:20 PM   #24
Ya I've heard that also. But don't know if it's true or not. Way I thought it went was the appliance drew whatever amps was needed. Now to many volts,,, that's a different story. Hehe, ya know it's the amps that kill ya also, not volts if ya get electrocuted.
Old 02-13-2005, 05:22 PM   #25
Default charger
i dont remember the charger is at my dads but ill be charging my 3000s at 5amps and the mv is 40mv but i cant change it(the mv).some1 said its to high to charge 3000s at but dunno?lmk plz
Old 02-13-2005, 05:27 PM   #26
Integrated's Avatar
5amps is the border line, my local hobby shop and alot of racing regulars trackside have told me not to charge above 5amps but apparantley you are spossed to charge at 7amp to get more punch in the stock class (27 rebuildable) i wouldnt like to take a guess at the batterys long term life though charging at 7amps !
Old 02-13-2005, 05:33 PM   #27
hugh janus's Avatar
i think a car battery has high crank amps not continuous
also novak black box for the millenium is 4.5 amps and you can charge with it that hi w/ no problems
hugh janus is offline   Reply With Quote
Old 02-13-2005, 05:36 PM   #28
I charge at 5 amps and call it good. I see guys racing stock who charge at 7 amps. But those are guys who only consider the battery a race battery for 5 cycles.
Here's a couple more links for ya to read
Myst Racing on batteries
Myst Racing on chargers
Myst Racing Home Page
Old 02-13-2005, 06:03 PM   #29
Default power supply
so charging at 5amps with a 7amp 12v power supply would be alright?
Old 02-13-2005, 06:10 PM   #30
Integrated's Avatar
yup i cant see why not, 2 spare amps is a fair amount.
chargers and power supplies cbl R/C Items: For Sale/Trade 10 01-21-2008 08:33 AM
2 Chargers and 2 Power Supplies mwiley R/C Items: For Sale/Trade 6 11-21-2007 10:08 AM
wtb chargers and power supplies tulsa R/C Items: Wanted to Buy 22 07-18-2006 05:35 AM
Question on chargers and power supplies koinonas Electric On-Road 3 05-25-2006 10:34 PM
BIG SALE- M8, XXX-S's, chargers, power supplies, etc.... cdelong R/C Items: For Sale/Trade 25 09-26-2004 05:57 AM
