Low Cost Electric Motors >
Old 02-09-2005, 03:42 PM
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
Default Low Cost Electric Motors
Im curious about the performace and life of lower cost motors (the ones usually under $30) as compared to high end motors. I have an Orion Revolution 10x2 in my Xray, but want to use something a little less exspensive for practice to save wear and tear on the race motor. One I was thinking about getting is the Epic Intense,
http://www2.towerhobbies.com/cgi-bin...?&I=LXJNF9&P=7
So if anyone has used this one, or one like it, your info will be greatly appreciated!
RCNitroDude999 is offline
Old 02-09-2005, 04:24 PM
sosidge's Avatar
Not having used one, it looks a little like a speed gems pro, which is a decent motor. Basically a machine wound P-94 mod (Trinity's last but-one-but-one-but-one mod motor...)
Generally, if the motor comes in the same kind of can and endbell as the company's handwound modifieds, they run pretty well. The cheaper motors tend to be made of sawdust rather than metal.
sosidge is online now
Old 02-10-2005, 01:32 AM
The expensive motors are expensive 'cause they're built by hand. The cheap motors are built by machines that do not have "feeling" for what they're doing. The main difference is that almost all the expensive motors are good, the machine wound motors go from good to bad. You could get a good motor when you buy the machine wound, but you're sure to get good motor when buying hand wound.
andsetinn is offline
Old 02-10-2005, 02:12 AM
Windtalkers's Avatar
Yupp..... the cheaper mods would be more costs saving but don't forget that the V2 mods require less maintenance... hence making the maintenance costs lower...
just my op.
Windtalkers is offline
Old 02-10-2005, 11:50 AM
Orion has an inexpensive line of mod motors svsilsble with the round V2 brushes
Search for "Orion Formula SV2"
Cost for the fixed timing motor is $25
Unregistered is offline
Old 02-10-2005, 12:04 PM
ya ive seen those, they look alright, the ball bearing versions are around $35.00 bux though...
Old 02-10-2005, 03:16 PM
Orion will be releasing even lower cost versions of their SV2 motrs called the Method and the Method R. These will be there lowest priced motor yet and will still probably be better then some companies mid-priced lines because of the SV2 technology using the round brushes.
corvin12xu is offline
Old 02-10-2005, 03:32 PM
what kinda brushes are used on those motors anyway?? The same ones as the revolution?
Old 02-10-2005, 03:37 PM
fathead's Avatar
I am using a Reedy Flashpoint 12x2 in my TC4 which is their budget motor and when I compared it to a 12x2Ti worlds edition side by side on a dyno in box-stock setup both with 12deg timing they had almost exactly the same numbers but the Flashpoint was slightly more efficient
And at almost half the shop price of the TI worlds I'm not complaining
fathead is offline
Old 02-11-2005, 06:04 AM
Trader Rating: 117 (100%+)
why not try a stock motor....liek the trinity monster pro or the p2k2 pro
Valentin.H is offline
Old 02-11-2005, 11:38 AM
i know those are good motors, but stock just seems to slow..
Old 02-11-2005, 12:44 PM
johnny boy's Avatar
Trader Rating: 328 (100%+)
Default good motors for cheap
hi i am the owner of high velocity and we are having a close out on the d6 mod motors they are going to be $45.99 and they come with three extra sets of the p-94 brushes if you have any questions you can e-mail me at [email protected]
the web site is www.teamhighvelocity.com
it hasen't been upgaded yet but will be soon
johnny boy is offline
