Old 02-07-2005, 02:24 PM   #1
NOZ69's Avatar
Default Boiling Gears ( 4 strengthening )
G`day ppl`s,
Years ago (15+) when i was last into R/C Cars & Slot Cars we used to boil our spur/diff gears to strengthen them.
The theory behind was a "uniform heat up & cool down"
We even used to add cloths die to colour them too.."bling Factor".
So my questions are
1 :- Is this still a common practice or has it been forgoten about.
2:- Is there another way..
3:- Or are the gears these days strong enough already.
Thanks Again
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 02-07-2005, 02:26 PM   #2
RCGaryK's Avatar
It's not done that often, mostly in some shaft drive cars internal gears. The boiling seems to make the gears less brittle and less prone to stripping.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-07-2005, 02:26 PM   #3
It is quite common to boil the bevel-gears on the Pro4. This makes the gears stronger someway, meaning less breakage.
Erlend is offline   Reply With Quote
Old 02-07-2005, 02:28 PM   #4
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Are you talking just the spur?....or dump the whole tranny into the water?
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 02-07-2005, 02:35 PM   #5
NOZ69's Avatar
GEES... thanks for the QUICK responses..
We used to do both spur & diff gears (all B4 assembly)...seemed to work back then,
but with the advances in technology since then, i`m thinking that may be it`s not needed as much.
Thanks Again
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 02-07-2005, 02:54 PM   #6
well....if you're making the gears a skosh harder, wouldn't that make the drive-train run a little noisy?
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 02-07-2005, 03:39 PM   #7
kufman's Avatar
boiling nylon spur gears would actually make them softer and less prone to shattering. It was common practice to boil associated nylon arms and stuff too. It was supposed to make them more flexable and less brittle.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 02-07-2005, 03:52 PM   #8
Send a message via AIM to greencactus3
and wont makeing gears harder mean its more easier to break?
greencactus3 is offline   Reply With Quote
Old 02-07-2005, 03:54 PM   #9
Mal
Registered User
Kaufman is correct, plastic doesn't act like metal where heat treating the material hardens it.
Mal is offline   Reply With Quote
Old 02-09-2005, 03:58 PM   #10
I've usually heard of this either the other way around, or WAY more heat the other way.
Iron can be case hardened by blowtorching it to glowing and throwing it into water. This makes the metal harder, but more brittle; It's much the same principle as glass. Woodworking tools have this done to them for a longer-lasting edge.
You can also freeze metals very slowly using liquid nitrogen, then let them warm up. This arranges the molecules in a more orderly pattern and makes the metal stronger that way.
Didn't know just boiling water could make that kind of change to metal structure.
Liko is offline   Reply With Quote
Old 02-09-2005, 05:37 PM   #11
scoobydo's Avatar
Since I own a Pro4, I have only heard of this practice still being used for the internal bevel gears on Shaft Cars.
The boiling just makes the bevel gears softer so they don't shatter on hard impacts or stress.
Pinions are mostly all aluminum nowadays and racing spur gears are usually soft enough to not need it.
scoobydo is offline   Reply With Quote
Old 02-09-2005, 06:13 PM   #12
KSI
KSI's Avatar
Send a message via AIM to KSI
when you heat treat metals, most of the time you are turning those little carbon "flakes" into round blobs to the material does cleave. FYI.
KSI is offline   Reply With Quote
Old 02-09-2005, 07:57 PM   #13
axel's Avatar
i have apro 4with the bevel gears. is ti ok if i dont boil them
axel is offline   Reply With Quote
Old 02-09-2005, 08:04 PM   #14
scoobydo's Avatar
If you have the 1.1 gears you should be fine.
You will still bust them in a hard crash no matter what you do or what version they are.
If you have the older gears, then I would probably recommend boiling them.
Either way, I would recommend having a spare set in your toolbox.
Old 02-09-2005, 08:07 PM   #15
axel's Avatar
i think i have the 1.1 so i think i'm good
boiling parts? cm367700 Electric Off-Road 6 11-17-2007 11:18 PM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 10:10 PM
boiling the wing... Tmachine Electric On-Road 16 02-10-2005 06:23 PM
boiling YOKES ! JayBee Electric On-Road 18 03-31-2004 09:24 AM
Boiling XXX-S Graphite Parts? ElectroNut Electric On-Road 4 01-28-2002 05:38 AM
