200mm chassis
How many electric cars are 200mm out of the box?
I'd like a car to run for fun at club level with some of those awesome 200mm bodies HPI do but tyres are a problem. We run on very dusty concrete so the grip is very low, everyone runs premounted Sorex 24's or CS22s or things like that. One option is to run offset wheels to make a 190mm chassis wider to 200mm but you can't find tyres which work unmounted. OFNA do the JL10E but we can't get it here in the UK without paying import taxes. Is the HPI Sprint 2 (the latest one, orange anodised) 200mm or is it offset wheels? |
1 Attachment(s)
Hi, The majority of TC chassis are 190mm wide. The one I use is the
Kyosho TF-5s which is 200mm out of the box so no need for offset tires when using HPI Bodies. See attached photo of the Kyosho Aston Martin DBR-9. Regards Norman2 |
I hadn't thought of the Fazer, its about £140 RTR here with the Aston or Porsche body, or £150 with the Subaru rally body. I'll do some research on that. Thanks!
http://www.modelsport.co.uk/kyosho-p...0&ChassisID=28 |
associated and xray for sure could do 200mm as well as any other touring car that uses the small arm mount blocks that attach to the bulkheads sideways. just use more shims, though make sure the dogbone seats properly ect.
My tc5 made it to 198mm but i needed longer arm mount screws to put it up to 200. no rule saying you cant run 200mm body on 190 car though. if your traction is low, you probably don't want wider anyway. |
Originally Posted by academygaz
(Post 10694997)
http://www.modelsport.co.uk/kyosho-p...0&ChassisID=28 As for drivetrain upgrades, I'm not so sure if it is compatible with the TF-5 parts or more so with the old FW-05 nitro. Maybe someone else will know. However, its better if you can get your hands on a TF-5s because there are so many parts available not just from the regular TF-5 but also from the ZX-5 buggy. |
This is pretty much a nitro TC that was converted to electric:
http://www.edam.com.tw/shopping_view.asp?sn=885# |
Originally Posted by thunderbt3
(Post 10695467)
http://www.edam.com.tw/shopping_view.asp?sn=885# That is a 235mm 1/10th nitro converted to electric. It will not fit the 200mm bodies the OP is looking to do. |
The specs say it can run a 200mm body. The pics on the website also show standard touring rear shock tower along with touring body mounts.
http://www.youtube.com/watch?v=cc6vZPIMP7c Looks like the guys in this vid were reusing a nitro TC body: http://www.youtube.com/watch?v=Zyk59...eature=related http://www.edam.com.tw/program/produ...1916514036.jpg |
Well it looks like they updated the car with narrower arms and shafts from their 200mm nitro TC.
However, my experience with Taiwan made RC is:
Not sure what its like in the UK for the OP but thats pretty much how its been in the U.S. |
Originally Posted by YR4Dude
(Post 10696328)
Not sure what its like in the UK for the OP but thats pretty much how its been in the U.S. http://www.edam.com.tw/program/produ...1916514254.jpg http://www.edam.com.tw/program/produ...9165134858.jpg http://imageshack.us/photo/my-images/198/captureak.jpg/http://http://img198.imageshack.us/i.../captureak.jpghttp://img198.imageshack.us/img198/9146/captureak.jpg http://www.rctech.net/forum/data:ima...BJRU5ErkJggg== |
Originally Posted by valk
(Post 10695252)
My tc5 made it to 198mm but i needed longer arm mount screws to put it up to 200. no rule saying you cant run 200mm body on 190 car though. if your traction is low, you probably don't want wider anyway. http://i.ebayimg.com/20/%21B6uusrg%2...7E%7E-1_35.JPG |
(Post 10696425)
Agreed. As for 200mm vs 220mm, it looks like all they're doing is putting on wider tires, cranking out the pivot balls, and adding an 1/8 style rear body mount.
http://www.edam.com.tw/program/produ...1916514254.jpg |
Tamiya Group C Chassis
1 Attachment(s)
The Tamiya Group C chassis is 200mm wide, and at it's shortest wheelbase setting (3 wheelbase settings available) you can run 200mm touring car or HPI made GT bodies. Big fat sticky foam tires, lightweight, easy to run-and the black "Speedline" wheels that come with the Mercedes look really good with most cars.
I have a converted NTC3
I love driving it, very adjustable, I converted to tc4 rear, nice tuff car
how much does it cost?
