Old 05-04-2012, 02:53 PM   #1
hairy's Avatar
Default I need REAL help with my Associated 6.1
I am so dissapointed in the company it is unreal.
First the car comes with a 48p spur gear, so the first thing i have to do is buy a new spur gear ( all I use is 64p) either that or bguy a bunch of 48p pinions.
SO I go to find a spur gear that will fit and get me to a 3.50 fdr and seems like there aren't any spurs out there that will work. Robinson racing's 93t 64p won't work. I call the company, Associated and the tech that answers the phone knows less about the car than I do.
DOES ANY COMPANY MAKE A 93T 64P SPUR THAT WILL FIT THIS CAR?????????????
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 05-04-2012, 03:02 PM   #2
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Did you look at Kimbrough or Xray.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 05-04-2012, 03:03 PM   #3
hairy's Avatar
I am trying not waste any more money by buying gears that don't work. Do you know if they will work in this car?
MERLIN RACING
Old 05-04-2012, 03:11 PM   #4
dfiantii's Avatar
What size 48 pitch spur gear did it come with?
TLR 22 2.0
Old 05-04-2012, 03:11 PM   #5
dc661's Avatar
Trader Rating: 129 (100%+)
Both of these gear types fit in the tc6.1, I personally have run both.
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 05-04-2012, 03:12 PM   #6
dfiantii's Avatar
dc what spur gear size are you running in your TC6.1
TLR 22 2.0
Old 05-04-2012, 03:25 PM   #7
dc661's Avatar
Currently I have a 92t spur but this is for 17.5 non-timing. That will change depending on my roll out and motor turn if need be.
-DJ Cranmer
Old 05-04-2012, 03:26 PM   #8
DARKSIDE's Avatar
I run 96t 64p in both TC6's...and pinion 47-56t...fdr from 4.2-3.4...they are Robinson part #4200..ish?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is online now   Reply With Quote
Old 05-04-2012, 03:28 PM   #9
dfiantii's Avatar
Ain't the forums grand? Ask and you shall receive.
TLR 22 2.0
Old 05-04-2012, 03:31 PM   #10
hairy's Avatar
I need to get to 3.50 and the 93t is a close as i can get but the gear does not have enough holes in it to mount it.
I have the 93t p#4193
MERLIN RACING
Old 05-04-2012, 03:38 PM   #11
LMRacing's Avatar
Trader Rating: 27 (100%+)
Mike, I have a 96T gear on my TC6 part number ASC4615 and I still have room in my car for a little more gear before the gear gets too close to the chassis (which if your not afraid to do a little bit of dremel work you could fit a little more gear in the car) but I think I should be able to fit a 100T gear in the car if I really needed to ASC4462 for the 100T 64P gear
LMRacing is offline   Reply With Quote
Old 05-04-2012, 03:39 PM   #12
DARKSIDE's Avatar
Ive never ran any 93...96 or 100 spur....what pinion do you have...and are you talking about the holes on the spur or motor mount?
Old 05-04-2012, 03:40 PM   #13
hairy's Avatar
Thanks but a 100 won't get me to a 3.50fdr needed
MERLIN RACING
Old 05-04-2012, 03:45 PM   #14
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
Not sure why you're set on the 93t? You can get a 3.5ish FDR with any spur within five teeth over or under that 93T, if not more.
Many brands of spurs will work, some may use two mounting hokes instead of three on the spur gear hub. Not sure why seemingly every one of your posts blames Associated for something or another? Finding a brand of spur that fits takes about thirty seconds and a Google search, it's not the end of the world.
If you haven't ever used it, gearchart.com can print you a handy dandy chart of spur/pinion sizes and FDR's. Just use TC5 when you make the chart, same end result.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 05-04-2012, 03:47 PM   #15
LasagnaCat's Avatar
64p spur numbers. Never had any use for the 100+ spurs at our huge local track, but the smaller #'d spurs we use all the time.
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46486 11-21-2017 09:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
Building my first real competitive car. yzracer758 Electric Off-Road 6 04-08-2008 11:51 AM
rc8--set up help ulrichcapri Nitro Off-Road 23 01-05-2008 03:22 PM
