Old 05-04-2012, 03:50 PM   #16
dc661's Avatar
Trader Rating: 129 (100%+)
Sounds like you have this gear: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEZ09 It will not work in your car, you're going to need to buy a different brand and or style of gear.
If you're going for a FDR of 3.5 means you have a 53t pinion, since it is obvious you have never ran the car before how do you know 3.5 FDR will get you were you need? You will once again run into having to change a pinion or gear. You should go to your LHS and stock up on a couple gear sizes I would start with buying a 88t,90t, and a 92t spur along with your various size pinions you should have. (This is if you were going to be running 17.5 all of the time.) Gears are very cheap you should always have at least an extra on hand at all times.
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 05-04-2012, 03:52 PM   #17
dc661's Avatar
Originally Posted by LMRacing View Post
Mike, I have a 96T gear on my TC6 part number ASC4615 and I still have room in my car for a little more gear before the gear gets too close to the chassis (which if your not afraid to do a little bit of dremel work you could fit a little more gear in the car) but I think I should be able to fit a 100T gear in the car if I really needed to ASC4462 for the 100T 64P gear
No need to ever dremel your tc6 I have run FDR ranges of 2.9 up to 6.2 and never had to cut anything as long as you take the time to properly find a gear and pinion to fit.
-DJ Cranmer
Old 05-04-2012, 03:52 PM   #18
@Art_Mighty's Avatar
Check out Precisions Racing Systems spurs. You can get a 64p spur with as little as 71 teeth.
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 05-04-2012, 03:54 PM   #19
LMRacing's Avatar
Trader Rating: 27 (100%+)
Sorry I thought maybe you were talking pinion to spur ratio.. 3.5 is an awfuly low FDR, VTA Car?
96T spur on a 55p gets you 3.49fdr
Get the associated Kimrogh spur gear, whole $3.50 and be done with it. Darkside already said up to a 56p fits on the 96s.
LMRacing is offline   Reply With Quote
Old 05-04-2012, 03:54 PM   #20
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
Correct. And don't forget about the 'third' mounting hole for the motor.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 05-04-2012, 04:03 PM   #21
It sounds like the OP is trying to use the two motor mount holes shown in the instruction manual and is searching for a spur with large holes like the stock gear...
You can use pretty much ANY off the shelf spur with the TC6/6.1 by utilizing the "3rd" motor mount hole towards the bottom of the mount/bulkhead....
JamesL_71 is offline   Reply With Quote
Old 05-04-2012, 04:09 PM   #22
hairy's Avatar
yea VTA 'bout ready to give up though
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 05-04-2012, 04:10 PM   #23
hairy's Avatar
Ther problem is mounting the GEAR not mounting the motor. the robinson gear only has two holes near the center not the needed three.
MERLIN RACING
Old 05-04-2012, 04:12 PM   #24
hairy's Avatar
Thank you
MERLIN RACING
Old 05-04-2012, 04:18 PM   #25
hairy's Avatar
3.5 is what the VTA class is restricted to. And yes I have run the car
and i won't comment any more on your condesending post
MERLIN RACING
Old 05-04-2012, 04:25 PM   #26
dc661's Avatar
Sorry if you took my post as condescending it was not meant to come off offensive to you. I only stated that you have not run the car since everything you have posted up to this point in time was addressed to being unable to use your car you just bought, because of the 48p gear and then the gear you bought and is unusable.
-DJ Cranmer
Old 05-04-2012, 04:50 PM   #27
LasagnaCat's Avatar
If the two line up with each other, one on each side, run it with two screws.
Old 05-04-2012, 04:53 PM   #28
DARKSIDE's Avatar
ive only use 2 holes...even on my TC5 and TC3...it works fine
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 05-04-2012, 04:57 PM   #29
Trader Rating: 21 (100%+)
Yeah, some spurs don't support all three (or six if you really wanna get into it) mounting holes.
Two are fine. I run mine like that all the time, even when I do have the option to use three. Lower rotating mass!
Either way, this spur works for me: http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
silencery is offline   Reply With Quote
Old 05-04-2012, 05:41 PM   #30
hairy's Avatar
Thank you all for helping me, the response has been great!!!!!!
I did not think it would work with only 2 screws but, it does THANKS AGAIN!!
MERLIN RACING
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46486 11-21-2017 09:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
Building my first real competitive car. yzracer758 Electric Off-Road 6 04-08-2008 11:51 AM
rc8--set up help ulrichcapri Nitro Off-Road 23 01-05-2008 03:22 PM
