Old 02-07-2005, 03:09 AM   #1
Default Adjusting rideheight.
Hi guys,
I do know how to adjust camber, toe in-out and droop.
But I dont know how to adjust rideheight.
How is it done ??
I have a Losi XXX-S.
Plz comment.
Snikkari is offline   Reply With Quote
Old 02-07-2005, 03:30 AM   #2
You adjust ride height by changing the tension on the shock springs. Assuming you have threaded shock bodies either screw the spring retainer down or up to change the ride height. If the bodies are not threaded you should have some type of clamp that can be moved on the shock body. Move both the right and left spring retainers the same amount until you achieve the proper ride height.
Lano is offline   Reply With Quote
Old 02-07-2005, 06:49 AM   #3
ntc3freak's Avatar
or adjust the droop.
ntc3freak is offline   Reply With Quote
Old 02-07-2005, 06:59 AM   #4
pookat's Avatar
Thumbs down
NO! Never use the droop screws to adjust ride height.
pookat is offline   Reply With Quote
Old 02-07-2005, 10:02 AM   #5
Ok, thanks.
But when I adjust the ride height at front to 6mm and droop to 3mm and lift the car up, the spring rattles loose around the shock body, there is nothing that holds the spring together (vertically)
Old 02-07-2005, 01:44 PM   #6
Mal
Registered User
It's ok for the spring to be loose when you pick the car off the ground. The spring doesn't need to be preloaded....
Adjust ride height by adjusting the shock collars.
For droop, set it with the shocks disconnected. You can either adjust droop using the droop screws or by using internal shock spacers and threading the lower shock ball cup in or out.
Mal is offline   Reply With Quote
Need help with adjusting throttle. nyczbubba Nitro On-Road 8 10-03-2006 05:56 AM
FS: HUDY Blocks and SPEEDMIND RideHeight & Droop Gauge Chris Furman R/C Items: For Sale/Trade 10 02-20-2006 01:51 PM
Adjusting Centax on PRP XR/8 Darthswan Nitro On-Road 9 07-25-2005 06:06 PM
Adjusting diff. in car?? revnine Electric On-Road 1 05-23-2004 09:27 PM
Help adjusting after mods djmtsu Nitro On-Road 6 12-19-2002 09:57 PM
