Old 04-30-2012, 06:34 AM   #1
Default Good and value for money - Lipo 5000/6000 2C for 10.5 turn motor
Dear all could you kindly recommend a brand/model of batt for
Lipo 5000/6000 2C for 10.5 turn motor brushless.
speed6 is offline   Reply With Quote
Old 04-30-2012, 11:20 AM   #2
UrabusDenis's Avatar
Some very serious racers in here are running Turnigy Nanotech packs with good results. I have one 5300 50C pack and have no complaintsm, it's better than most of my brand name LiPOs
Alpha Plus - alpha-rc.com
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 04-30-2012, 02:11 PM   #3
Suspended
Whatever pack you get, make sure they are ROAR APPROVED , or else you might not be allowed to race....
bertrandsv87 is offline   Reply With Quote
Old 04-30-2012, 02:43 PM   #4
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
I'll assume that you're trying to be helpful this time, but for the original poster... ignore that misguided suggestion as it's written.
Check to see IF you need a ROAR approved pack before buying? Yes.
Intentionally purchase something you may never need without checking first, based on the suggestion of a stranger on the internet? No.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 04-30-2012, 02:47 PM   #5
Suspended
I am always helpful . Roar Approval is helpful !
Old 04-30-2012, 02:55 PM   #6
Suspended
Here is some more help : Gens Ace 2 S 5000mah 50C pack for $40.50 , and it's ROAR APPROVED !
Old 04-30-2012, 03:21 PM   #7
Trader Rating: 27 (100%+)
Yup either the gens ace 5000mah 40 or 50c lipos, or the Turnigy nanotech 2s batteries. The 6000mah 65c battery is like 45 bucks. You just have to wait a while cuz they ship from hong kong.
hyujmn is offline   Reply With Quote
Old 04-30-2012, 03:29 PM   #8
I have been told that it has to be at least 60C or else i will lack punch and top speed. Is this true?
Old 04-30-2012, 03:40 PM   #9
LasagnaCat's Avatar
C ratings on lipos are similar to the watts per channel ratings on stereo gear... the seller puts just about anything on their sticker and there's no standard for how it's measured. A higher rated pack can provide more punch. Whether or not you believe the rating on the sticker...
Old 04-30-2012, 04:18 PM   #10
did anyone benchmark these lipo batteries in order to check / compare.
Old 04-30-2012, 04:25 PM   #11
Suspended
I don't know about testing packs against each other, but I rely on what I see them do on the track with top drivers behind the wheel..... That's the best test there is !
Old 04-30-2012, 06:45 PM   #12
Hi, I did some benchmark tests:
http://www.rccartips.com/lipo-battery-comparisons.htm
Will soon test some Turnigy and update the info.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 04-30-2012, 08:05 PM   #13
Suspended
Turnugy and Zippy. Enough Said.
RogerDaShrubber is offline   Reply With Quote
Old 04-30-2012, 08:13 PM   #14
jhautz's Avatar
Trader Rating: 85 (100%+)
+1
I have the 50c Gens Ace 5000mah and the 65c Turningy nanotech 6000 packs and I personally think the Gens Ace packs have a little more punch. Plus I like that they are slightly lighter cuz they are only 5000mah. C rating isn't everything. It varies from manufacturer to manufacturer.
jhautz is offline   Reply With Quote
Old 04-30-2012, 08:20 PM   #15
Trader Rating: 49 (100%+)
While this may be true, I'd bet the best racers are given cherry picked batteries. Maybe not in all cases, but you probably wouldn't get the same battery a top notch factory driver would.
Also, I could give a top notch racer a turd battery, and chances are they'd still kick my butt while I have a higher quality battery.
I'm not sure about the ROAR approved comment either. Unless the track is sanctioned by ROAR, most tracks will accept hard cased lipo's unless otherwise stated. If the track requires Roar approved that's one thing, but many tracks do not.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
