Old 04-29-2012, 08:11 AM   #1
Default TT-01D XB Nissan Silvia Coppermix
Hi,
I have XB TT-01D, with hpi 7.2v 3300mah battery.
I would like to use Lipo battery, can the stock ESC and motor handle it?
Or I have to get a better ESC and motor?
If I have to buy a new motor, which motor is good for drifting?
I mean not the best motor, just the good/better than the stock motor.
rakoon is offline   Reply With Quote
Old 04-29-2012, 09:41 AM   #2
Originally Posted by rakoon View Post
Hi,
Stock setup is fine. Just get a lipo alarm/buzzer so you know when your battery is running low.
If you're getting a new motor/ESC, go for a Hobbywing brushless set. It's pretty much the cheapest branded set you can get.
abdul basit is offline   Reply With Quote
Old 04-29-2012, 09:48 AM   #3
Thanx for the info, appreciate it
Old 04-29-2012, 02:07 PM   #4
You're welcome.
You'll find answers to most questions on the internet. For example, if you searched for "TEU-101BK lipo", you'd get information regarding your ESC and if it's Lipo compatible.
You can get answers faster, and sometimes better ones too.
Goodluck.
Old 04-30-2012, 04:18 AM   #5
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Is your ESC a TEU101, or a TEU104? The 104 is compatible with Lipos. If you've ot the 101, for not much more than the Lipo alarm costs, you could buy the 104. Keeps the wiring on the chassis a bit neater.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 04-30-2012, 07:43 AM   #6
The 104 has a low voltage cutoff suited to the LiFe batteries and not Lipo's!!! It can still be used with Lipo's but you cannot rely on it to protect your lipo as the voltage cutoff is set too low for that battery type.
mr lee is offline   Reply With Quote
